Question about Hotpoint Dryers
My general electric dryer DDE8200GBLAD will not heat. Where is the heating element and/or Thermostat located ?
My dryer runs but does not heat. I'm trying to locate the heating element and/or thermostat. Can you help me with a diagram...???
SOURCE: I NEED OWNERS MANUAL TO KENMORE DRYER
goto sears.com and under parts type the model# hit enter. Then type manual and it will cost you $2.30.
Posted on Oct 16, 2007
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Posted on Apr 03, 2008
SOURCE: how to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
Posted on Aug 21, 2008
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
No heat in dryer mode
In electric dryers, heat is generated by the heating element. The element is a coil of heating wire enclosed in a metal chamber. Electric current flowing through the coil creates heat and the air being pulled through the chamber absorbs this heat. If the element is defective then it will not heat. It can be tested with a multi-meter for continuity. Unplug the dryer and remove the front or rear panel to locate the element so it can be tested.
The high limit thermostat is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
Dec 02, 2013 | Splendide 2100 Vented Washer-Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Mar 25, 2011 | Roper REX3614KW Electric Dryer
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
Element not heating
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance: http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad). 2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 19, 2010 | Whirlpool LER4634J Electric Dryer
My dryer has no heat
If the model number you posted this question under is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
The MOST common causes of heat related problems: 1. Blown Thermal Cut-Out. 2. Missing 1/2 your input voltage at the wall receptacle (the dryer will still run with half the voltage missing, but won't heat - double check your source voltage at the receptacle and/or your circuit breakers. 3. Bad power cord, causing 1/2 the input voltage to be missing. 4. Blown heating element. Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful. NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 02, 2010 | Whirlpool LER4634J Electric Dryer
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Blowing cold air
There is not a reset button on an electric dryer that I know of. If a dryer is blowing air at all, that tells me that the blower assembly and drum motor are working. If you have not heat it is generally caused one of the following:
1. Bad thermal cut-out - located near the heating element housing. Should read a SHORT (0 ohms on an ohm meter) if good. If bad, it is generally a good idea to replace the TCO along with the Hi-Limit Thermostat (mounted right next the TCO in most cases) because the TCO is designed to protect the thermostat and heating element. If the TCO fails, it is likely that the thermostat could also be damaged.
2. Hi-Limit Thermostat failure - located near the heating element housing. The thermostat opens when the internal heat reaches about 157 degrees (on most dryers). This helps regulate the dryer temperature and helps protect the heating element. If it reads a constant OPEN (infinity reading on an ohm meter), replace it along with the TCO (as mentioned above).
3. Bad Heating Element - located under the drum on some dryer models and in the rear on others. The element should read about 9-11 ohms if good. If they go bad, the element will generally burns itself OPEN.
I will need you model number (located near the dryer door opening) in order to give you better advice on how to access the inside of the dryer. Post back with comments and let me know. I hope you find this helpful.
PS I hope I didn't insult your intelligence, but some people are little more saavy than others, so I try to explain things in the simplest of terms.
Jan 14, 2008 | Dryers
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
