Question about GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop
ZGU385 sparking, one of the 5 knobs has light is on even in off position
GE monogram ZGU385, continuous sparking on all burners even when all knobs in off position, but one knob has light on. When any knob is turned on, sparking stops. What's the problem and how to fix it?.
SOURCE: one burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Posted on Jan 18, 2009
aborcass
  • 2651 Answers
SOURCE: GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Posted on Mar 17, 2009
  • 30 Answers
SOURCE: I cannot get a igniter spark from an of the 5 burners
Check fuse in plug!
Posted on Aug 09, 2009
SOURCE: GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Posted on Jan 03, 2010
heatman101
  • 43501 Answers
SOURCE: I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Posted on Sep 30, 2010
Ge monogram ZGU366LPSS one burner does not light up
It will light with a lighter just not the igniter which means the igniter is not working, sometimes they crack and run to earth, remove the top and turn off the lights you will see it sparking where it's running to earth.
Mar 09, 2014 | Thermador Cooktops
Center Burner stays lit and will not stop trying to ignite unless it is unplugged. If I need to order parts please tell me what I would need to fix this problem.
Hello Donna ,
If by saying "stays lit" ya mean that the flame goes off when turning off the knob yet it continues to spark all the time ?? if yes that's whats happening the flame goes off but it keeps sparking whats wrong it that the switch that turns on the spark when the knob is turned is bad and that is what needs to be replaced. GE only makes that switch available in a complete assembly with all 5 switches and the wiring for it. It's not to bad to replace that actually,what ya would need to do to replace that switch harness asm. ya need to take off the main top which can be done by removing the burner grates and caps from the burners,then is the outer center of each burner will be 2 screws remove those screws from all burners then the all 5 knobs and the top will lift off,that switch harness has keyed plugs and will only fit in one way so its not to bad to replace it. The part number for that switch/wire harness asm. is WB18T10381 it could be purchased at your local appliance parts store or online at; searspartsdirect.com apdepot.com partselect.com apwagner.com repairclinic.com
Thank you for using Fixya.Com,if you should require further assistance please reply and i will be happy to help,
GENE
Oct 04, 2011 | General Electric Monogram® ZGU385NSMSS...
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Igniter keeps sparking even though burners are on
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
Sep 08, 2009 | GE Monogram ZGU36L6HSS / ZGU36N6HSS...
Hello: One of the five knobs on the top of our GE monogram stainless-steel gas cooktop Model # zgu385 broke, and needs to be replaced. Can you help? Thanks, Daryl D.
DARYL - GO ONLINE TO REPAIRCLINIC.COM AND YOU CAN FIND THE KNOB YOU NEED, THEY MAY SELL THEM SEPPERATLY I'M NOT SURE BUT THERE PRICES ARE THE BEST I'VE SEEN IN A WHILE
Aug 24, 2009 | GE Profile JGP636 Gas Cooktop
One burner requires a match to light
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop Logo
35 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
