Question about Dimplex Heating & Cooling
DIMPLEX SIV20 ELECTRIC HEATER
FIRE MADE BANG AND HASNT WORKED.CHANGED THE FUSE IN THE PLUG BUT NOTHING HAPPENED
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Posted on May 19, 2009
  • 415 Answers
SOURCE: Dimplex Electric Heater Model Number DF 3003 fan
Dimplex has a Service Manual for your Heater. I recommend requesting the manual through their Literature Request website. I located the owner's manual and the troubleshooting guide via their website, but it appears you will need to request the Service Manual.
Hope this helps.
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: won't fire
It may also be the high temp switches under the 2" inlet/outlet header. The 150 degree high-limit switch sits horizontal and corrosion happens often there. But be careful removing as if the header is corroded and the switch is also, water will flow out , so be ready to bypass the heater. You will have to replace the header. Try to jumpe that switch out and I'll bet the heater fires up.
Posted on Aug 07, 2010
SOURCE: Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Posted on Dec 08, 2010
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
I need to change the bulb in a dimplex brayford electric fire, how do I get the fake coal plastic off.
The plastic ember bed lifts out with a little effort. To assist you, I have included a link to your Bradford model Owners manual that you can download and print for future reference.
http://www.dimplex.com/customer_support/technical_and_troubleshooting?docsearch=GDS26-BW1052&type=&dlang=
Dave, I hope this helps you.
Apr 29, 2011 | Dimplex Compact Electric Flame Stove...
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
Motor in dimplex fire/heater not turning
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
70 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
