Question about Electrolux Epic 6500 Vacuum
Electrolux 2100 hot motor light came on because hose was plugged
I've cleared the hose and the vacuum has cooled but it still does not start. Is there a reset button or something that I should be doing in order to get the motor to start?
    Scholar:
  • 44 Answers
The thermal switch should reset itself after it has cooled. If it still won't restart after a while longer, put a a new bag in the machine and turn the machine off and back on. The only other things that should keep it from running other than the thermal overload, is the bag being full or the bag not being present. Either of these faults would need to be corrected and then the machine switched off and back on to clear them. I hope this helps. Good Luck!!
Posted on Jan 03, 2009
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Overheats shuts off (protecto relay/)
The Electrolux vacuum hoses don't have a fuse of any sort incorporated into them. The resettable relay is in the machine they're connected to. In your case, judging by the shape of the machine end of the hose, your vac would be what was called a Special Model, with a Canadian type hose. These machines did have a resettable fuse in them which was supposed to protect the motor from overheating. If this feature is happening frequently, either the hose is partially plugged, or the motor is having a seriouis problem of it's own. It should be inspected by a qualified Electrolux technician, and they're getting harder and harder to find since they went to a franchise system of sales offices. Good luck.
Nov 09, 2013 | Electrolux electric hose models 2100
I own a elecrolux 2100. the power light comes on but the vacuum wont start
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 17, 2011 | Electrolux Vacuums
I JUST REPLACED THE MOTOR IN THE MODEL 2100.WHEN I PUSH ON THE START SWITCH, THE PROTECTION LIGHT COMES ON AND THE VACUUM WON'T START.WHAT IS THE PROBLEM?
Things that may cause this.
Mar 10, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I have an electrolux 2100 it wont turn on
Jan 05, 2011 | Electrolux Vacuums
I have an electrolux 2100 canister vacuum that turns right back off every time we push the power button. We have a new bag installed on it, and it will stay turned on if the hose is off, but as soon as we...
Dec 29, 2010 | Electrolux Vacuums
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Vacuums Logo
232 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
