Question about LG Washing Machines
WM2075CW REPLACE BEARINGS .LG TROMM WM2075CW
3 Suggested Answers
  • 2187 Answers
SOURCE: LG Tromm WM2075CW will not spin. I've done
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
Posted on Aug 27, 2009
SOURCE: LG TROMM wm2075cw gives an error of OE...
Washer has a filter, at the bottom left handside of washer, which needs to be cleaned out. Refer to manual. Worked for me :)
Posted on Dec 04, 2009
LG WM2075CW seems to leak AFTER a load is finished. Wtare found front left under washer and also in the drawers of the pedestal. Anyones best guess?
(1) If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
(2) Check the tub seal for tears or cracks.
(3) Check the door boot seal for condition.
(4) Also check the tub-to-pump drain hose for cracks or tears.
(5) Lastly, check the drain hose for condition.
Replace whichever offending part that is found to be defective.
Mar 01, 2015 | LG Washing Machines
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm dryer electric sounds like bearings are starting to seize
if the bearing are going it will sound like a plain taking off grinding banging them you will end up with grease all over your clothes was told from an engineer once never put you m/c on any thing over 900 rpm spin speed as the bearings ar not designed to go any faster i have a hotpoint and its over 12 year old still sounds like new and never had a problem with it hope this help
Sep 23, 2012 | LG Tromm Electric Dryer
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM wm2075cw gives an error of OE... and won't spin out the laundry.
Nov 27, 2009 | LG Washing Machines
Aug 27, 2009 | LG Washing Machines
LG Tromm Model # WM2075CW doesn't drain - water everywhere!
This is joyce
I hope you have not been waiting long for this answer, go to the website lg.com dowload your document on your washer put in your model # first and then it will give you all the info you need on that machine even trouble shoot it and codes. I hope this helps.
thanks,
joyce
Feb 04, 2009 | LG WM1814CW Front Load Washer
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
Feb 16, 2008 | Dryers
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
