Question about Samsung SW62ASP Top Load Washer
My samsang washer wa10u3 stops working during rinsing and the error code 5E appears
4 Suggested Answers
  • 43 Answers
SOURCE: fault code 5E
possible pump problem
try cleaning out the filter
Posted on Nov 10, 2008
SOURCE: samsung WF7708N6W not draining. code 5e & 4e
code 5e showen washing want spin
Posted on Aug 15, 2010
  • 6277 Answers
SOURCE: My samsung washer model no.
Samsung 'LE' decodes as 'natural drain/water leak error' whatever that means!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 05, 2011
E pa au u5 5e
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
May 15, 2014 | Frigidaire Affinity FAHE4044MW 27"...
Washer fault code 3E what does it mean
during washing and rinsing when a motor restriction is sensed, the motor stops and then proceeds
to the next waterflow action. if the motor stops working and this happens in one direction 10 times,
the error code 3e will be displayed.you should be able to clear the error code by turning your washer
off and on. or powering it down and then powering it back up. good luck!
Feb 21, 2011 | Samsung Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Samsung error code 3E?
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
Samsung SW62ASP Top Load Washer Logo
66 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
