Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year is a troy built tiller with model no. 95815
  • 48 Answers
SOURCE: Troy tiller tines
they should point inwards and towards the rear of the machine
Posted on Oct 17, 2008
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
  • 332 Answers
SOURCE: Can't start my Troy Built Tuffy tiller
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Posted on Mar 31, 2010
I have a troy bilt rototiller horse, serial #7146C. Can you tell me what year it is?
Go to the Troy Built web site, find the contact phone number, call them and tell them what you want to know. Give them the serial #, and they may want to know the model also. They should be able to tell you what year it was made. Hope this helps. I will Actually see if I can find out the info for you. I will be right back. Sara I just talked to troy built, this is not the serial # this is a model number if you can check again for the complete serial# I can get you the year your tiller was made.
May 01, 2016 | Troy Garden
My rototiller is missing the data tag with Model and Serial No. The only id I have is the engine SN. Would like to identify engine mfg and Troy-Bilt tiller model.
Google search Troy-bilt Proline Tiller and search through the images to find the model most like yours. I believe the engine was built by Honda.
Good luck,
May 10, 2015 | Troy-Bilt Garden
I have an old troy built junior tiller, the only numbers found as on the engine. 130202 0135-12 81100107 what year is this model? and were can i get a repair manual?
hello ,you can contact troy bilt at 1-800-269-6215 and check for your manual or go on line troy bilt.com tillers parts manual..add model number,
Feb 06, 2012 | Troy-Bilt Garden
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
May 03, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
26 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
