Question about Bell Sports Bell F12 Bike Computer
When my product battery worn out, I replaced it with a new one and found out that my odometer was also reset to 0. How can I add it up to my older 953 km? Thank you.
Reset maintanice light
Undo your battery for a couple of minutes worked on the older models. I believe this is the procedure for yours.
Turn ignition key to 'ON' and press the odometer button until the display reads ODO... not Trip A or B.
Turn ignition key to OFF.
Hold in the same button you used in step 1.
While holding the button in, turn ignition key to 'ON'.
ODOMETER will change to
5 dashes - - - - -
Then 4 dashes - - - -
Then 3 dashes - - -
Then 2 dashes - -
Then 1 dash -
THEN all zeros 0 0 0 0 0
Then back to the correct mileage
The Maintenance Required light should blink and go out.
Mar 10, 2015 | 2007 Toyota Corolla
I have. Ducati DS1000 multistrada 05, had to remove flat battery, it was out for 2 days. Put new battery in, now my odometer has been reset to 0 zero, why?, can I recover old odometer reading.
haha ps don't tell ducati ... you will have to go to a main dealers for this and still I doubt they have the tools to sort this one ....memory is saved on your cdi unit (basically a mini computer ....removing the battery should NOT have affected it
Mar 03, 2015 | Ducati Motorcycles
Chevy colorado gas odometer
gauge is worn out. its the little motor behind the gauge needs replaced its called a stepper motor.. can be found on ebay motors.
Apr 20, 2014 | 2007 Chevrolet Colorado (Extended Cab) New...
Chevy cavalier 2005 87000 miles remote flakey, odometer won't display milage but will display trip data?
Hello William,
The key fobs are wearing out and need to be replaced. Sometimes taking them apart and cleaning the switch contacts and battery contacts will extend their lives but they are not built to last.
I believe your vehicles ECU sends the mileage data to the instrument panel cluster...in which the LCD odometer display has failed.
Aug 10, 2017 | 2005 Chevrolet Cavalier
Hp 953 driver
you have said hp 953 but not the exact model number.
but few matches i am providing.
below is HP XT953
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=59820
or
go to www.hp.com click on support and drivers and choose the model of your pc or laptop and then download the needed drivers.
if you google HP 953 there are two models coming HP X series and HP G series both having 953 number. hope this helps
Feb 17, 2012 | Compaq (158272-001) Motherboard
The digital odometer reads "error" and the engine hrs.screen reset itself to zero. Can I reset the computer by diconnecting the battery?
Yes take your battery terminals off and hold them together for about 10 seconds that will reset your computer.
Sep 23, 2009 | 2005 Chevrolet Silverado 1500HD
I have a Toyota Landcruiser Prado SX 3.0 1994 Turbo Diesel, Engine No 1 KZ-0065839. The Electric Switches for the 4WD and Hub Lock light up when they are pushed on but the car does not go into 4WD. I...
το προβλημα ειναι ενα μικρο συρμα που κανει επαφη σε ενα απο τουσ δυο τροχουσ μπρωστα
Jul 17, 2008 | 2006 Toyota Land Cruiser
New engine
no they are not required to, because the mileage is on the whole car and not on the engine, since there is many many parts than get older whit the mileage like wheel bearing transmission etc,
the original mileage has to stay the same, the only time they are required to reset the mileage is when the instrument cluster is been replace, it has to read exactly same as the old one,
example, if your car is currently reading 36000 by replacing the cluster it has to be set at 36000, having a new motor does not mean than the car is new again,
Jun 22, 2008 | 2004 Isuzu Axiom
Bell Sports Bell F12 Bike Computer Logo
57 people viewed this question
Top Bell Sports Cycling Experts
Eric Hidle
Level 1 Expert
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
