Question about RCA Televison & Video
Line up red blue yellow
A fuse went out on our television, rca home theater 1999 model P60923BL. We replaced, and now the colors do not line up, and we would like to know how to do this...?
  • 167 Answers
Hello it sound's like you need to set your. convergence on your set. or you will need to replace the (ICchip's ) on your convergence board. to fix the problem. your having. !!! me know after you try to reset the convergence on your set. and we can go from there."GOOD LUCK" and thank you
Posted on Jan 03, 2009
Need to hook up LG tv to phillips cd/4 head hi fi and RCA surround sound
Ok: I will guide yourself through "hook up" process.
1. connect your TV set to your VCR, using 3 wires RCA cable(Yellow, red, white) to "Video1" input, yellow only! The other 2(sound channels) connect to "home theater/DVD unit. Use "aux" input.
2. Connect your DVD video output. yellow or 3 colored( green, blue, red) component cables to your TV's Video 2 or "component 1" input.
Now you'll be able to use your TV as a video monitor for your VCR and DVD.
The sound will be handled by DVD/Home theater. In case your TV is a very modern, all you can get out is: direct digital sound stream. Your home theater must be equipped with coaxial(orange) input(looks like RCA plug) or optical input. Or both. You must use proper cables to connect TV to Home theater.
sorry, but it requires some patience and thorough reading of user manuals.
Otherwise, it's "level 1" difficulty. nothing you may damage, due to installation.
Good luck,
Feel free to ask for more help, if needed.
Dec 14, 2011 | LG 42LC2D 42 in. LCD HDTV
How to fix 3 lines on top of the tv red blue and yellow
what tv is this..whats the model.. i had the same thing on mine it was the covnergence fuse that went out also had some soldering that had cracked on the convergence board resoldered and works like new.... make sure the tv is unplugged though...
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
Hi, I just bought a samsung blue-ray. I want hook
i can help with that have you looked on the back of the tv at all the jacks you have look at the color of the jacks some are red and white those are for audio and the yellow is video you need a pair of cables that will conect from you dvd to your samsung that same color on both ends their RCA cables or analog cables
Oct 29, 2009 | Onkyo HT-S780 System
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Only plays in black&white
Allot of times one of the video RCA connections can go bad.
Replace the RCA Video wire, Yellow. If you have component (RGB), this is a common problem when the wires are crossed. The Blue is the B/W feed and one of the other Green/Red, may be bad or crossed. If you haven't changed any wires since the color went out, it is still possible that one of the wires jiggled loose. If you have S-video, try replacing that. When I say replace, maybe check the connections are plugged in well first, then replace.
Hope that helps!
Jan 12, 2009 | Sony DAV-C770 System
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Philips theater system dvd/radio/surround sound
I need your exact model number of HTS, and the manufacturer and model number of your television to be of maximum assistance.
There are a couple possibilities:
1) you could have red, yellow, and whites plugged into the red, green and blue slots
2) If you have more than one output (S-video and red/yellow/white, for instance), the signal could be splitting - try unhooking one of the outputs (preferably the S-Video)
For a more detailed solution, send me your model/manufacturer of TV, and the model of Philips HTS.
Feb 21, 2008 | JVC TH-M505 System
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
