Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore ultra bake gas oven mod 665 pilot light
How do i light the pilot
fridgetech
  • 473 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 11, 2007
  • 833 Answers
SOURCE: Kenmore Ultra Bake Oven Won't Heat Up
Turn the breakers off and wait 10 minutes and then on.  If this doesn't clear the problem, you'll need an electronic timer module.  Electrical spikes cause problems like this.
Posted on Nov 28, 2008
  • 5 Answers
SOURCE: kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Posted on Feb 15, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore gas oven won't light. The pilot light
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
Posted on Sep 07, 2009
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
I have a kenmore self cleaning gas oven. the pilots light, the broil kicks on, but preheat won't start. what can i do?
Ok well heres the deal. I'm assuming that because this is a self cleaning oven then its probably fairly new in which case you probably don't have actual pilot lights on there but "glowbars" which are called ignitors. If this is the case, and you can see your ignitors for the bake and broil both glowing then chances are you have a weak bake ignitor. If the ignitor is not getting hot enough, then it will not send enough current to the gas valve to energize it (allowing it to open and let gas in). If its not glowing at all you can just get a voltage detector (you can buy them at walmart for about 10 bucks) turn the oven on and use your wand to see if the ignitor is getting power. If it is then its going to actually be open or shorted.
Overall deal is that 95/100 times if you have a gas oven with ignitors and its not baking its and bad or weak ignitor. They cost about 60-90 bucks.
If your oven does indeed have a pilot light then you will have a bad thermocouple or possibly obstructed burner tube.
Hope this helps _MJ_
Feb 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultra bake oven is locked
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Sep 12, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
56 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
