My hp laserjet printer cannot print even it was installed corectl
The main problem is that the printer does not blink the light does not come up when it is connected to eletricity,it steams and stops but when the lid is open it starts to steam again and paper will pass thruogh without any print on it. I will appreciate a solution
  • 3 more comments
  • mctchrist Jan 07, 2009
    the model is hp laserjet 1300, no I don't use remanufactured cartridge
  • mctchrist Jan 26, 2009
    It was very useful as far as I also know that I have to use the intallation CD. the main problen is that I dont have the installation CD,because I also bought the secondhand, so I am using plog and play system to install that is why I am having problem.It maens that I do still need assistance from any expert in field,
    Thanks very much .
  • mctchrist Jan 27, 2009
    THANKS I WILL TRY THE SOLUTION B4 I CAN POST A RATING
  • mctchrist Feb 04, 2009
    the prnter is not working after all the support I still need install my printer hp laserjet 1300help to
  • Nat Miller
    Nat Miller May 11, 2010
    What is the model number of the printer? Do you use new or remanufactured cartridge?
HP Link for complete printer system software: lj1150_1300prnsys-en.exe
Posted on Jan 27, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
My hp laser jet 1300 is blinking orange and cant print please get me a solution
The flashing orange light is a basic attention light. Check the following:
1. There is a known good toner cartridge installed
2. There is paper in the tray
3. The long tab on the top of the inside of the cartridge access door is not broken
4. Connector J210 on main board is intact, tight and all 3 pins are present
5. That the drum drive engagement is working properly and the contact is present
6. The main motor connector is seated tightly
Jul 09, 2009 | HP LaserJet 1300 Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
HP Laserjet P1008 not Printing
What you need to do is go to the printersmenu in the control panel and then see which printer is set as the default printer.If the selection is correct,see if any documents are pending in the print queue or not.If it still does not solve your concern then your printer has taken up an IP address that is no more recognized by your computer.So you need to change the port to which the computer is printing.If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz.
Apr 08, 2009 | HP Color LaserJet 2600n Printer
HP 2550n will not print
From the HP User's Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link to download the user guide:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00189910/c00189910.pdf
Oct 14, 2008 | HP LaserJet 2550n Printer
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Feb 14, 2007 | HP LaserJet 1320 Printer
53 people viewed this question
k24674
jasbo
jasbo
