Question about Williams 1403622 Gas Compact Heater
Thermostat does not work
I bougth 2 heaters and I instaled them both one of the thermostat did not work. I would like you to send me one I went to home depot to see if they could give or exchange the themostst that does not wock for one that would but they did not have those heaters any more. so please send mea thermastat it is winter and I will send you the borken thermastast. or a telefone # where I can talk to someone!
Rene
  • Williams Master
  • 2,364 Answers
Try direct energy they might be able to help you or know where you could get the part youn need
Posted on Dec 30, 2009
Tip
INSTALLING A NEW THERMOSTAT
WHEN BUYING A NEW THERMOSTAT THE WIRING MY SEEM CONFUSING MOST TIMES IF THE WIRES ARE PUT ON THE SAME TERMINALS AS OLD SUCH AS IF RED WENT TO TERM. R. IF YELLOW WENT TO Y. ETC. THE MOST COMMON CONFIGURATIONS ARE RED-POWER24VOLT-R
WHITE-W HEAT/ COMMON-C GREEN-FAN-G
YELLOW-COOLING-Y
PLACING THE WIRES ON THE NEW THERMOSTAT THE SAME AS OLD ONE WAS WIRED WILL WORK HOPE THIS IS HELPFUL TO HOMEOWNERS. A PROGRAMABLE THERMOSTAT CAN SAVE HUNDREDS EVERY YEAR.
on Jan 30, 2010 | Heating & Cooling
Can the timer of a frig when turned to defrost the heaters should turn on well I just installed new heaters and thermostat but not working what can the problem be???
Dennis,
The three things needed for your defrost heater to come on are the heating element, and thermostat, which I gather from your note you have already replaced, and the timer which sends the signal to the thermostat which when closed, sends the signal on to the heater. I would go ahead and try the timer control and see if that does it for you. Hope this helps!
Jul 10, 2015 | Refrigerators
Temperature gauge don't work..
Sounds like you may have a problem with your coolant temperature sending unit or thermostat, locate your sending unit, unplug the electrical connector run a jumper wire across the 2 wires inside the connector the gauge should read hot when the jumper wires are connected and when you remove the jumper wire it should go back to cold this verifies your gauge and all related wiring are working properly, if it doesnt work as described you either have a wiring problem or a bad temp gauge, next if your heater output is suffering you more then likely have a weak thermostat staying open or partially open replace the thermostat with a new unit, however if you arent experiencing any heater trouble replace your coolant temperature sending unit because your thermostat is more then likely working properly.....
Dec 10, 2010 | Pontiac Grand Am Cars & Trucks
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
My thermostat went from cut on & off frequently to not turning on at all but it it works if I have it set to heat and switch it from Auto to oN. Is thermostat broken, it's only 2 years old.
Remove the red and white wires from the R and W terminals on the thermostat. Cross them together and wait to see if your heat starts. If it does, trash the thermostat. If it does not, you have a furnace or wiring issue.
Dec 10, 2009 | Honeywell Electronic Programmable...
Water temp gage sometimes it works and sometimes it doesn't
Likely the temp sending unit has failed. They aren't very expensive. One on 4.0 engine is on the thermostat housing but don't know which engine you have.
Blower problem could be the resistor pack but not sure exactly where it is on yours, it is always on the heater box and generally looks like a flat fiber plate with four wires going to it.
Dec 02, 2009 | 2002 Jeep Liberty
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Williams 1403622 Gas Compact Heater Logo
123 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
