Question about Quantum Fireball Computers & Internet
Jumper Configuration for slave
Jumper configuration 6480at
physicistFL
  • 34 Answers
SOURCE: Can I use a WD3200AAJS
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Posted on Jan 08, 2009
localwonder
  • 6784 Answers
SOURCE: jumper settings wd1600
yes, you are correct.
Posted on Feb 20, 2009
  • 211 Answers
SOURCE: slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Posted on Mar 29, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: wHAT ARE THE JUMPER SETTINGS FOR THE SLAVE CONFIGURATION
In a general slave configuation, there is no need for a jumper.
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Posted on Sep 04, 2009
Cant find the slave drive on boot
Master/Slave configuration I am assuming you have IDE hard drive and not SATA. SATA is a small cable IDE is a wide 40 wire flat cable. You must install the jumper on both drives as master and slave. On the old WD HDD master has jumpers between 5 and 6 and slave jumper between 3 and 4. Default is jumper between 1 and 2 which is cable select which you use for a single drive.
Nov 09, 2013 | Dell Inspiron 531s Desktop Computer
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Can I use a Maxtor DiamondMax Plus 60 (5T040H4) 40.9 GB like Slave?? Thank you
Of course you can use it. Put the jumper to set the configuration as "slave" and insert the a plug from the ide cable. If you put the put the jumper to "cable select", put the slave plug and it should work great.
Mar 15, 2010 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
There is usually a diagram on the drive showing the jumper configuration.
Mar 16, 2009 | Maxtor Hard Drive
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
Hello!
Ken
Jan 07, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
