Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
How to build a box for a Pioneer TS-W307D2 12
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Posted on Mar 09, 2007
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
hotratchet
  • 952 Answers
SOURCE: pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Posted on Jul 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
What size of box in need Pioneer TS-W310D4
if its pioneer shop at walmart lol !!! try a speaker shop or read the manual it has that kind of info in it
Feb 25, 2013 | Pioneer Ts-w309d4 tsw309d4 1400w 12" Dual...
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How do I make a sub box for my single ten inch re sx 10 inch sub dat is 1000 rms. Da box needs to be tuned to 35 hz
yeah, you likely cant build a box to tune 35hz... try just building a box that has correct spec by the manufacture for ideal operation, and adjust the gain accordingly, that's where you will attain your desired hertz, oh and by the way hertz refers to signal, and pulse rate,
Sep 12, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
What size of box in need Pioneer TS-W307D2 12
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I need bow specifications for a pioneer ts-w308f
Hello, The problem with the enclosure is that you purchased a "free-air" sub, which is designed to NOT use an enclosure. You need to simply mount the sub on a baffle (board) that covers the whole entire rear deck of your vehicle, and seperates the inside of the trunk from the cabin of the vehicle. Use sealant to keep the two compartments sealed air-tight and mount the sub on the baffle-board. The other option, is to build a very large box (larger than 3 cubic feet) that would be incredibly huge for the subwoofer, as a free-air, it has a VERY high QTS, and relies on a massive amount of air behind the woofer to allow it to reach low frequencies. The best bet would be to get rid of the free-air sub and purchased a sealed enclosure subwoofer for use in a small (.6-1 cubic foot) sealed box.
Feb 16, 2010 | Car Audio & Video
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
Pioneer box
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Spl box 12inch pioneer subs pls
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Pioneer ts w33c
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
113 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
