Question about Radio Shack Pro-2052 Scanner
Realiatic pro 2022 scanner squelch does not work
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
radiorob1
  • 17 Answers
SOURCE: Radio Shack PRO-49 handheld scanner. Turns on,
The "hot" pin inside the BNC antenna connector is probably broken or disconnected internally.
Posted on Oct 10, 2009
  • 5603 Answers
SOURCE: I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING
Check if one of the batteries MIGHT be in backwards.
NEXT check EACH cell as occassionally you get a bad one brand new.
Posted on Nov 14, 2009
  • 1274 Answers
SOURCE: constant squelch noise
turn the squelch till silent
Posted on Feb 15, 2010
Dodgem250
  • 68 Answers
SOURCE: pro 95 scanner squelch does not silence receiver
Your squelch control may be back or your control needs to be aligned properly on the circuit board. Ship it in for repair if you wish. dodgem250.com
Posted on Apr 16, 2010
I have a Pro 96 radio and for whatever reason it suddenly just make a squelching sound.
hello this is natural thing with a scanner what you were probanly noticing was a static discharge some where in the vacinity of your scanner to avoid this ajust the squelch level 3/4 turn maybe this will solve your problem
Feb 14, 2011 | Radio Shack Pro-96 Scanner
Pro 95 scanner squelch does not silence receiver regardless of knob position,subsequently receiver will not scan.
Mar 31, 2010 | Radio Shack Pro-95 Handheld Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Squelch quit working in regular scan mode PRO-528
Just fixed my squelch problem; I don't know how it happened but Resistor 138 was burned & intermittant. It was so badly burned that I could not read the color code but it measured 880 ohms intermittantly. I replaced it with an 860 ohm carbon resistor & all seems well; time will tell. R-138 is located on the circuit board right behind the squelch potentiometer. R-139 is immediately behind the pot & R-138 is next to R-139. All I had to do is remove the 4 screws on the back of the case & the unit splits in half. I clipped the old resistor out leaving a bit of the old leads so I could solder in the new resistor without having to get to the backside of the circuit board. Scanner is working as I type this & I hope it does not burn out again. Hopefully this is the same problem in your scanner & an easy fix. Good luck.
Bob Tomlin
WB1AIJ
Dec 11, 2008 | Radio Shack Pro-95 Handheld Scanner
NO SQUELCH
Sincerely
Greg Stevens
e-mail
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
My pro-2018 won't scan anymore.
you may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Jan 31, 2008 | Radio Shack Pro-2018 Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-2052 Scanner Logo
63 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
