Question about Dell Precision Workstation 690 - 750W 64Bit XP Dual Core Intel Xeon Processor 5120 ... PC Desktop
How to replace Dell BIOS battery?
System thermal solution compromised AHCI BIOS not installed error message
3 Suggested Answers
7Sleven
  • 320 Answers
SOURCE: I need to enable AHCI
Hi Jordan,
You should be able to access your BIOS setting when you first turn on the pc. The first screen you see will tell you (briefly) to push either the Esc button, or F8, F12 to access the BIOS setup. Once your in the BIOS you may have to hunt down the control your looking for but the options are not that many and you should be able find it within a few minutes. Word of warning, by changing settings in the BIOS, you can cause your pc to act much differently or not even boot up correctly. So if you enable the Advanced Host Controller Interface (AHCI) and it does not act like you want it to, you can always change it back.
Hope this helps
Posted on Dec 29, 2010
yourpc
  • 190 Answers
SOURCE: my computer will not boot
This can happen on some models. Turn the computer off and unplug the tower. Press the power button to discharge any stored power. Plug it back in and press the power button. You will probably get this message again but let the computer sit. Windows may be working in the background trying to start back up. Let it go for like a half hour to an hour. If it does not start you may have to do a system restore or a repair install to make windows start correctly again. If waiting longer does not work for you then let us know and I can give you instructions on how to continue the repair process.
Hope this helps... Dale
Posted on Apr 20, 2011
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
How to fix this error code: 2000-0146 without replacing hard
Make sure the bios setting for rhe hard drive is set to "SATA not AHCI" you may need to reformat and reload the operating system...
Aug 23, 2011 | Dell XPS M1530 Laptop
Bought new hard drive for mini 1012 dell bios sees new hard drive but when i try to install windows xp , xp says no mass storage device detected.
In the bios change the drive options to anything but AHCI if possible. You will need a windows xp driver and USB floppy disk to install the AHCI or SSD driver. It's also referred to as an F6 Floppy. Dell should have the download you need.
Jul 18, 2011 | Dell Inspiron Mini 1012 Netbook...
Having dropped my Samsung R530 (nothing obviously broken), when I try to stsrt it it is coming up with the message:- "Boot From AHCI CD ROM: Operating System not found" Any ideas?
Hi tony prother,
"Boot From AHCI CD ROM: Operating System not found" error is because the system is booting the CDROM of the system and its not detecting an installed Operating System. You need to check if the system still detects the Hard Drive of your laptop on the Bios page. To go to BIOS reboot the computer and tap F2 on the system and on the bios page check if the hard drive is detected then go to then BOOT Tab select the hard drive as the first boot priority and reboot the system.
If the hard drive is not detected it might be damage, you can get intouch to a local tech to check and backup the files.
Thanks for using Fixya.
Jan 28, 2011 | Samsung R530 (NPR530JA02US) PC Notebook
Hi, I own a Dell Inspiron 1525 laptop and recently had a hard drive failure. When I boot the computer it gives me an error message saying there is no bootable devices. I was told that I would need a new...
I have a suspicion that you made a bios default for some reason ..and the AHCI feature for your HDD was activated and the system can not see the hdd for that reason ..so ..I suggest to enter to BIOS settings ..and on the advance settings ..look for drives..IN the place where the HDD and the disk drive is seen select the HDD that it is recognized , and the AHCI function needs to be disabled if it is on ...and after that the computer will boot if there is nothing else wrong with it ..
remember look for AHCI and disable ..save with F10 and enter ..and reboot ..If you have a functional windows ,the laptop will boot OK after that ..
Oct 03, 2010 | Computers & Internet
I can not setup windows xp in my dell latitude e6400 laptop.I set BIOS (F12), select "System Configuration", "SATA Operation" and i change it from "IRRT" to "ATA. But no work.When i start windows xp setup...
Try this hints:
1.Press F2 to enter BIOS on start up
2. Expand Drive section
3. Go to SATA Operation
4. Check and change from Raid Auto/ AHCI to Raid Auto/ATA
Good Luck
Apr 11, 2010 | Dell Latitude E6400 Laptop
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Sep 29, 2009 | Dell Inspiron 1545 Notebook
Dell Precision Workstation 690 - 750W 64Bit XP Dual Core Intel Xeon Processor 5120 ... PC Desktop Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
