Question about Samsung J700 Cellular Phone
I keep dropping my phone
Some times its down the radiater and on the ground and on tiles.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
I would advise getting a pair of new hands, if that is not a possibility, you may try getting a wrist strap or neck lanyard to help keep a hold of your phone. Good Luck.
Posted on Sep 09, 2009
How to remove cment stains from walkway tilese?
cement is reduced by hydrochloric acid
so test with a spare tile first to see if the acid affects the tile surface
place a few deops of the acid in a container of water and use a cloth to wipe over the cement stain
make sure that you use rubber gloves
keep adding a few drops until you see the cement start to beak down
Mar 03, 2018 | Washing Machines
Tip
Tips on how to Get ready the Subfloor intended for Ceramic Tile Installs
Ceramic along with porcelain tile are generally among the most rigid supplies intended for floors. They require the subfloor that's which will take into account that, without any fluctuation and also motion. If ceramic and also porcelain tiles are generally set up on the wrinkled surface area, a person manage the risk connected with allowing the tiles to be able to break and also loosen. Locations recommendations on tips on how to get ready the subfloor for a tile assembly.
one. The installation of ceramic tile along with porcelain tile with a real piece
Repair many splits along with wrinkled pads from the real subfloor before the assembly - specifically crucial in the event the tile will be becoming specifically bonded to the real.
If connected with subfloors along with great splits, look at the chance of removing a large portion of real piece along with replacing that using a brand-new one as an alternative to patching all the splits.
Intended for negative splits from the real piece, smooth that along with real filler, and also related substance.
In the event the real subfloor will be brand-new, that have to be still left to be able to treatment 29 days and nights previous to tiling.
Personal hygiene will be paramount. Aside from virtually any surface area supplies, you'll want to take away virtually any grease intrinsic and extrinsic stains, and also alternative contents that have tarnished the piece because most effective it is possible to.
Bare cement backer snowboard can offer powerful, flat working surface to put in tiles on for those who have the real wood subfloor.
only two. The installation of ceramic tile along with porcelain tile with a plywood subfloor
The plywood subfloor have to be structurally seem along with capable to help support the assembly. Tile floors are generally hefty along with tile is a very difficult substance. It is going to bust and also dislodge in the event the surface area bends less than the fill.
Don't forget which you are required an extremely flat working surface to be effective on. If desired, stone dust the plywood into level the subfloor.
Plywood have to be set up over an acceptable subfloor along with have to be a minimum of one 1/8? heavy if put together with the subfloor. Interior-grade plywood along with particleboard are not deemed strong sufficient for a tile assembly.
three. The installation of ceramic tile along with porcelain tile over plastic floors
Non-cushioned plastic along with linoleum which is structurally seem along with unencumbered with high motion can certainly take action just as one suitable subfloor.
Padded plastic seriously isn't the perfect subfloor. You need to take away the plastic ground along with virtually any remnant adhesive utilised to the plastic assembly.
In some instances, it is possible to eliminate the plastic once more, however , not the adhesive. Use the skinny placed which is endorsed from the backer snowboard maker.
If it seems hard, you might want to lay out the backer snowboard along with thinset.
several. The installation of ceramic tile along with porcelain tile over a pre-existing tile ground
It is possible to sometimes keep the tile ground set up along with employ thinset specifically over that, and also take away the tile using a hammer, dependant upon the best way high the ground must sit down relative to be able to doors and also other internal factors.
In the event the current tile ground is focused with a mortar mattress, it really is very difficult to eliminate the tiles with no removing beautiful mortar mattress.
If you're the installation of specifically on the older tile floors, uncertain " up " the existing tile along with stone dust document. Clean using a degreaser along with analyze a little community suddenly intended for bonding.
In addition, test the height from the ground while using height of doors along with showcases. Any good thinset enable you to set up the brand-new ground.
Incorrect to order subfloors
Subfloors in order to avoid intended for tile installs are generally those that are inclined to bend, increase, contract, and also warp. Virtually any high motion may loosen the tile along with soda the grout. Incorrect to order subfloors have to be succeeded and also taken care of using a suitable underlayment. Here's a list of no-go subfloors:
Padded plastic
Border set up plastic
One layered plywood
Flake snowboard
Particleboard
Computer chip snowboard
Hard wood (strip) floors
Luan plywood
OSB planks
Masonite
Linen steel
Which kind of subfloor considering the installation of the ceramic tile on?
Continue to searching for the ideal tile to your renovation venture? Please click here to be able to consider the amazing group ceramic along with porcelain tile.
Wholesale Ceramic Tile from China Manufacturer Best price
on Jul 31, 2015 | Building Materials
30 yer old caloric stove wher light pilot
http://www.partselect.com/Caloric-Stove-Parts.htm
Jan 04, 2014 | Kitchen Ranges
Cutting porcelain tile with wet saw and it breaks at the end of the cut?
Porcelain tile has to be cut painstakingly slow, especially the last inch or two to prevent the splitting problem you are having. When you are cutting tile, the sawblade rides up just a little as the tile is being fed into it. You'll notice it if you stop pushing the tile through and watch the head drop down just a bit. When you are getting to the last part of the cut, reduce the pressure you are using to push the tile into the blade so the blade can wear away the tile with little pressure and vibration as possible.
Dec 30, 2012 | Mk Diamond MK 370 TILE SAW
I replaced my radiator on my 2004 with a 2.2 and it seems like the thermostat is not opening. It can not get the air out. It seem to just to over heat and push the coolant out. Randy
REPLACE THERMOSTAT IF TOP COOLANT COOLANT HOSE GOING TO RADIATOR IS HOT TO TOUCH THERMOSTAT OPEN. TO BLEED COOLANT SYSTEM FIRST YOU NEED TO ADD COOLANT TO THE COOLANT OVER FLOW JUG UNTIL COOLANT LEVEL STOP DROPPING AND STAY AT FULL COLD MARK.WAIT 3 MINUTES IF COOLANT DROPS ADD MORE COOLANT UNTIL COOLANT STAY AT FULL COLD MARK.WITH RADIATOR OVER CAP OFF CRANK ENGINE FOR MINUTE WATCH COOLANT LEVEL AT OVERFLOW JUG.IF COOLANT DROPS ADD MORE COOLANT IN THE OVERFLOW JUG.WHEN COOLANT LEVEL STOP DROPPING IN OVERFLOW JUG.SCREW BACK ON THE RADIATOR CAP TO OVERFLOW JUG.WHILE ENGINE IDLING WATCH TEMPERATURE GAUGE WHEN TEMPERATURE START CLIMBING TURN OFF ENGINE WAIT A WHILE KEEP FROM GETTING SCALDED.WHEN COOLANT COOL DOWN SOME. PLACE A LARGE RAG OVER THE COOLANT OVERFLOW JUG OPEN CAP LITTLE AT A TIME UNTIL PRESSURE RELEASED, THEN REMOVE CAP ADD MORE COOLANT IN THE OVERFLOW JUG TO THE FULL COLD MARK.THEN REPEAT THE PROCESS SCREW BACK ON THE COOLANT OVERFLOW RADIATOR PRESSURE CAP.THEN START ENGINE WATCH TEMPERATURE GAUGE WATCH COOLANT TEMPERATURE GAUGE WHEN COOLANT TEMPERATURE START RISING TURN OFF ENGINE AGAIN WAIT UNTIL ENGINE COOL DOWN ENOUGH TO KEEP FROM GETTING SCALDED TAKE PLACE LARGE RAG OVER RADIATOR CAP WHICH IS THE COOLANT OVERFLOW JUG CAP OPEN CAP LITTLE AT A TIME UNTIL PRESSURE RELEASED ADD COOLANT UNTIL AT FULL COLD MARK. WHEN YOUR COOLANT LEVEL STOP DROPPING.AND TOP RADIATOR HOSE VERY HOT THERMOSTAT OPEN AND AIR IS OUT THE COOLANT SYSTEM. MAKE SURE YOUR COOLANT OVERFLOW JUG HAS COOLANT IN IT,WHEN ENGINE COOL DOWN CHECK COOLANT OVERFLOW JUG KEEP COOLANT LEVEL AT FULL COLD MARK.BECAUSE IF OVERFLOW JUG IS EMPTY THATS A SIGN RADIATOR COOLANT LEVEL LOW.WHEN OVERFLOW JUG EMPTY IT WILL ALLOW AIR GET IN THE COOLANT SYSTEM AND CAUSE CAR TO OVERHEAT.WHEN REPLACING THERMOSTAT ALSO REPLACE THE RADIATOR CAP ON THE COOLANT OVERFLOW JUG.
Aug 09, 2011 | 2004 Oldsmobile Alero
When i turn off the car the fan continues to run?
Many cars have this feature. The fan will run for a few minutes at a time until the coolant in the radiator drops below a certain temperature. Most vehicles with this feature will have a warning label on the radiator shroud indicating that the fan may start without warning when the engine or radiator is still hot. The only time you would need to be concerned would be if the fan continues to run without turning itself off, and causing the battery to be drained.
Feb 19, 2011 | 2003 Jaguar X-Type
Dropped my LG CF360 cell phone on the tile floor. phone operates fine but screen is now blank. it appeared to be fine immediately after dropping it but now the screen is blank? any ideas?
yes. this is a common fault with any phone that falls on the tile floor, especially if it lands using the screen(even if it doesnt, the screen might still be affected). the only solution is to send it to a repairer because it would require the attention of an expert due to the crack or damage done to the main display screen which in most cases would have to be replaced with a brand new one
Nov 08, 2010 | LG CF360 Cell Phone
I have a 1995 Pontiac Grand Prix GTP 3.4L DOHC....... The engine is over heating (yes it has coolant in it).... and I had noticed a leak in the coolant so we replaced the radiator (which had a hole in it)...
REPLACE THERMOSTAT TO BE ON THE SAFE SIDE.IF YOU PUT NEW RADIATOR IN MORE LIKELY YOU NEED TO BLEED COOLANT SYSTEM CHECK COOLANT LEVEL WHEN ENGINE COOLS DOWN. YOU HAVE AIR IN COOLANT SYSTEM.AIR WILL EXPEL AND COOLANT LEVEL DROPS ADD MORE COOLANT UNTIL YOU HAVE RIGHT AMOUNT COOLANT IN RADIATOR.DONT DRIVE CAR UNTIL COOLANT SYSTEM BLEED.WHEN THERMOSTAT OPENS TURN OFF ENGINE WAIT A WHILE THEN CHECK COOLANT LEVEL KEEP ADDING UNTIL COOLANT LEVEL STOP DROPPING IN RADIATOR. USE LARGE RAG OVER RADIATOR CAP TO KEEP FROM GETTING SCALDED BUT WAIT UNTIL COOL DOWN ENOUGH SO YOU WONT GET SCALDED.
Sep 01, 2010 | 1995 Pontiac Grand Prix
No problem: I need to know the specs of a ceramic tile cutting blade that will fit the Hitachi C7SC circular saw that I possess. Your machine is the best
Any blade 7 1/4" in diameter or smaller with a 5/8" arbor will fit on your saw. Your saw is capable of cutting tile but the dust that will be drawn into the saw by the fan will be very hard on your brushes, armature and bearings severly shortening it's life. Tile saw motors are usually sealed or made to work with water to keep the dust down. Don't use water with your saw, it's not grounded.
Aug 31, 2010 | Garden
Samsung J700 Cellular Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
