Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
There is power but no image
Nothing happens matter what button I use, I tested the cable it works on another monitor
  • 1,996 Answers
These are the troubleshooting steps for No Image:
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
If that doesn't seem to help, you can see a copy of the User's Guide here:
I hope that leads to some improvement for of luck
Posted on Mar 28, 2009
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
How to check if youre computer problem is video card not the LCD of the Laptop
try to connect external monitor. turn on the computer. press Fn and F8 - this is to toggle LCD screen of laptop and on the external monitor - may vary from model of computer. if nothing happens, turn off computer. unplug all cables, then remove the battery. press power button 5 times - to remove residual charge from computer. plug in just the AC Adapter then perform Built in self test on LCD of computer by press and hold D and power button. if still no image on LCD screen then it is the LCD, if it performs the built in self test then the problme is the vdeo card.
on Mar 01, 2010 | Computers & Internet
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
Nothing happens when the power button is pushed.
make sure the power cable is inserted properly. try to unplug it and put it back again. if it doesn't work, try with a different cable, use your friend's cable with your monitor to check it out. if it works, then the problem is with the cable, if it still doesn't work, reply to this message please.
Jan 04, 2011 | Samsung B2230 LCD Monitor
Monitor power button just flashes blue then yellow , does not work on other computer or other cable. Though it has to be solid yellow, It flashes even with no video cable. Thanks in advance for any...
If you have the power button "on" on the monitor and you unplug the vga cable from your monitor you should get a messege about the cable being unplugged. Sometime the inverter in the monitor can go out and you will be left with a very dim screen or no image at all. You can call up a local computer store and see if they can test the monitor for you. Taking the monitor into a repair shop will more then likely cost you more then a new monitor. I would check to see if the monitor is still under warranty or simply just replace it.
Best of luck..
Nov 18, 2010 | Hannstar I-Inc TW-191D Monitor
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Screen is black and power button gone amber colour.if you press buttons on monitor it says,in power safe mode press any key or move mouse. when you do this nothing happens
Restart the computer and turn off power save mode. If this is vista the power save mode has a lot of problems and can cause things like this to happen.
Sep 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
EMachine monitor quit
This could be one of three components:
1. The video card
2. Video Cable (cable from the monitor to the computer)
3. The Monitor
The way I would determine this is:
I would try to plug this monitor into another computer that you know works with other monitor. If this is a home computer and you don't have another computer to test this take it to a friends house. Use a different cable to connect the to computer and power if possible. Then switch out to the old hardware (e.g. power cable, video cable.) If all has been determined to work then it's probably the video card.
If you can do this at all I would suggest trying a new video cable they are cheap. Usually 10 bucks at the most or borrow on from someone else. If this is a DVI cable they are a little more expensive. VGA cables look like this btw
Dec 08, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
254 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
