Question about Waring Pro WO50 Cordless Wine Opener
How to remove the battery in a waring pro w050 cordless wine opener
3 Suggested Answers
SOURCE: thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Posted on Apr 14, 2009
SOURCE: need manual for waring pro wine chiller model pc150
Go To wamhomecenter.com pull up product, check product details, click on product then print
Posted on Jun 06, 2009
Wine opener won't recharge
Do you really need an ELECTRIC WINE BOTTLE OPENER?
I've been using all my life a manual one, never had to rechage it.
May 02, 2015 | Oster Cordless Rechargeable Electric Wine...
How do change the battery in a Waring wine bottle opener?
It is not available. Someone bought one on ebay and soldered it in. I am going to try it myself.
Feb 19, 2015 | Waring Pro WO50 Cordless Wine Opener
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
May 21, 2014 | Waring Pro WO50 Cordless Wine Opener
Cork stuck in wine opener
amazing that noone has answered this question including the people at Waring - I have no idea how to do this
Feb 18, 2014 | Waring Pro WO50 Cordless Wine Opener
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
Jan 15, 2014 | Waring Wwo100bj Pro Wwo100pc Professional...
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
How to replace a battery in a waring pro wine opener
Replacing requires some soldering skills.
1. Remove two screws in bottom end and pull off the bottom sheath.
2. Remove six rubber plugs that camouflage six screws.
3. Remove the six screws. The opener will come apart in halves and the motor assembly may drop free but will still be connected so be a little careful. Take note of the orientation of the larger spring near the bottom and the positions of fittings that mate with the shell.
4. Unsolder two leads connected to the old battery pack and remove it.
5. Now you have options for replacing the battery pack. The pack consists of four Nickel Metal Hydride batteries connected in series.
a. Buy replacements (I didn't do this so I don't know if a pack is available that is already assembled). You might have to buy four same-size batteries and assemble the pack yourself. You can determine size by cutting the shrink wrap away from the battery pack to expose the actual batteries.
b. Buy standard AA (or AAA) cells, rechargeable (Nickel Metal Hydride) cells that are readily available everywhere.
6. (Unnecessary if you found a pre-assembled pack). Assemble a battery pack by soldering battery terminal to battery terminal such that all four batteries are in series. You can arrange adjacent batteries with a plus terminal and a minus terminal next to each other. You can make the four batteries into a pack by winding them with electrical tape.
7. (Unnecessary if you chose step 5A). Using a sharp knife or a Dremel tool, whittle away most of three ribs that are formed into the plastic shell. There are two ribs to do in one of the shell halves and one(+) rib in the other shell half. The (+) rib is near the connector block mounted under the operating switch and you can decide how much of it to whittle away also. The objective is to get the new battery pack to fit in the shell halves when they are re-assembled.
8. Solder the plus(red) wire and the minus(black) wire to the new battery pack -- those are the two wires removed in step 4.
9. Add padding if you desire to keep the battery pack from rattling around inside the shells.
10. Reassemble the shells and the bottom sheath.
11. Enjoy your wine.
Cork will not come out of opener
This is from Jen8926 in another forum and it worked for me (push up the inner sleeve an inch or more inside the main tube): Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Mar 02, 2013 | Waring Pro WO50 Cordless Wine Opener
Need manual for waring pro wine chiller model pc150
Feb 22, 2009 | Waring Wine Chiller - Black
Waring Pro WO50 Cordless Wine Opener Logo
588 people viewed this question
Top Waring Home Experts
Andrew Taylor
Andrew Taylor
Are you a Waring Home Expert? Answer questions, earn points and help others
