Question about Electrolux EW1000i Front Load Washer
What does it mean error 11 in wash machine electrolux 106510 w
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
rdrsp
  • 85 Answers
SOURCE: Error E145
the ecb ( electronic control board ) has detected a malfunction.
check all wiring to the ecb and replace if needed.
also try unplugging the machine for no less than 5 minutes to clear all codes to see if the problem is intermitent or not, hope this helps....
Posted on Oct 26, 2009
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: HiI Hve an Electrolux W4139N washing machine that
That model does not exist on our system and Error code 27 does not exist either.If you can find the product number inside the door then we may be able to help you,just re enter your query on the system..
Hope this helps.
Posted on May 29, 2010
What is the meaning of EL error code in electrolux top load washing machine?
Please refer this link and you will get all the information :- https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load/
Apr 04, 2018 | Electrolux Washing Machines
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
I have a Kenmore elite cook top that is displaying a code C 11. What is the meaning?
ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/318200292.pdf
ftp.electrolux-na.com > lassomption
SERVICE DATA SHEET - 30" Induction Cooktop with Ceramic Glass. IMPORTANT. DO NOT .... C11. Shorted keypad. The defective control will flashes the error code in its display. 1- Cycle power on ...
May 24, 2015 | Kenmore Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
Electrolux washing machine error code e30
Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Jul 25, 2013 | Electrolux Washing Machines
EF 2 error is showing on my electrolux EWF14811 washing machine what does this mean?
it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
Aug 15, 2011 | Electrolux Washing Machines
Electrolux ewf 1435 washing machine
Feb 16, 2008 | Electrolux EW1000i Front Load Washer
Electrolux W375E
if you go to electrolux laundry systems you will be able to download the operating manual for the W375N. all error codes are on this PDF doc..
Nov 26, 2007 | Washing Machines
Electrolux EW1000i Front Load Washer Logo
19 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
