Question about GE Washing Machines
Shoe lace stuck under agitator in GE profile washing machine
Shoe laces stuck under agitator
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: I have a LG front
Ouch! I'm guessing that the shoe lace wrapped around the shaft from the inner tub and cannot be pulled back into the wash tub. That sucks, because the only way to get at it then would be to remove the motor rotor, sepperate the two halves of the outer tub, allowing the inner tub to be removed to access the offending shoe lace. If you know what you're doing, it's about a two hour job. My advice: Just live with the noise. Please don't bother rating this, as anything but a Fix-Ya drops my score.
Posted on Jan 03, 2009
  • 713 Answers
SOURCE: I have a shoe lace wrapped around the agitator how
get a long sharp nife and cut off.
Posted on Feb 22, 2011
kevin_getz
  • 1031 Answers
SOURCE: I have a Ariston Avtxf 149 that is locked down with f12 error mode.
F12 is a communication error.
The electronics aren't talking to each other properly.
F5 means the Pressure Switch jammed on full
Possible pump block, check pump etc. for blockage
Check pressure switch, wiring and module connections. Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages.
Posted on May 29, 2012
How do i tie my shoes?
I am trying to understand the problem here. Nike shoes that are equipped with laces are usually sold with some. If the laces are broken, you can get more at a shoe repair shop. If it is for disability that you ask, then the occupational therapist may not have given you the techniques you need yet.
Apr 10, 2015 | Nike Clothing Accessories
Tip
Tips on how to Choose Wear and Care for converse all star shoes
Buying Converse shoes is quite simple. Make sure one's just like the other, from the way the toe guard sits on the shoe to the distance between the eyelets. Check to see if the tongue pokes out about an inch over your laced-up shoelaces on each shoe.Here are some tips for wearing your converse shoes: •Wear quality socks that allow your feet to breathe.•Keep your laces untwisted within the eyelet space so they'll last longer and look fresher. •Make Converse your own by choosing laces in a different color or size. •Center the tongue of the shoe so they'll be more comfortable on your feet.•Make sure to confirm that wearing Converse will not create or magnify any foot problems. Bunyons, pronation, supination will all lead to more serious problems and later it will be harder to find shoes that fit and feel comfortable. When caring for your Converse shoes, just say no to bleach! Use soap and water to clean shoes without damage.
on Oct 27, 2010 | Clothing Accessories
My moccasins shoe lace came undone how do i fix that
You can replace the lace and then tie it up to keep it from falling off. Leather thong laces are likely the best choice because it will look close to the original.
Apr 12, 2014 | Clothing Accessories
Shoe laces are weak
You dont give me much information. Are the eyelets OK? If not, they can rip the laces. Get nylon laces and they are stronger than cotton.
Mar 17, 2014 | Clothing Accessories
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
My light blue emericas are dirty & idk how to clean them it saddens me :(
Get a big zippered laundry bag (available at grocery stores in the laundry aisle or big stores like Wal-Mart or Target). It should be big enough to hold both shoes; if not, get two bags, one for each shoe. Take the laces out of your shoes, and put them in the bag with your shoes. Use the hand-wash or gentle cycle on your washing machine, and your regular detergent. You can wash other clothes with your shoes.
After the washing cycle ends, take your shoes out of the bag and let them dry in the sun. You might need to dry them with a bath towel first if they are dripping wet. Good as new!
May 01, 2011 | Emerica Laced Shoes
How to remove inside door panel
It's usually the window winder that presents the problem . Remove all visable retaining screws ie; Grab handle , Internal door opening lever , Button on top of panel (if applicable ) etc . The majority panel are a pop snap on type . Remove the winder lever withthe aid of a shoe lace or thin piece of cloth material, The winder is retained by a horse-shoe shaped spring clip. .... Pull the shoe-lace/ material in the opposite direction of the winder retainer clip and it will easily come off, but it is a spring clip and may fly off so be careful. Good luck
Apr 10, 2010 | 2004 Mitsubishi Endeavor
Take off front door panel
Mar 22, 2010 | 2004 Ford E150
Drum won't spin caused by piece shoe lace got stuck in drum. dryer was still on but drum not turning.
first of all never dry shoe laces in a dryer a=or anything simular to it. The drum has a very thin seal between the front edge of the drun towards the front panel of the dryer. That front panel will be needed to be removed so you can clean the seal out really good and thoroughly inspect it for tears, rips or and missing peices. If beyond using replace it. While you are in there inspect the belt around the drun and tensioner too. The belt should be tight without cracks in it and the tensioner & bearing should move freely for good performance
Feb 06, 2010 | Dryers
I have a LG front load washer, and a shoe lace got stuck in the little holes on the back. The end of the shoe lace is made of some hard materials and it gets bend, so got stuck in the little hole. I...
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
113 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
