Question about Acer Aspire 5315 Notebook
Only stays on about 3 seconds when turned on
When i turn the laptop on, it only stays on about 3 seconds. never will show anything
  • hemingways Jan 03, 2009
    laptop says that there is media problem with the hard drive
This is a action cam ei2000 will not turn on or stay on, comes on for like 3 seconds shows pic then disappears
can you get 'in to it' by plugging it into a pc or laptop, if so battery may be faulty
Dec 28, 2015 | Cameras
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
Mar 21, 2014 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
My screen wont show anything
try to turn on/off the pc , remove all the cables and battery . Press and hold the power battery for 5 seconds . Reinsert the cables and battery. Turn on the pc, if the screen did not show up, please call tech support for possible repair...
May 15, 2010 | Computers & Internet
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
I press the power button and it turns green for bout 10 seconds then it turns red. Nothing shows up on the screen er anything.
this is meant to happen if u turn the ps3 off it flashes for about 10 seconds and stays on standby with the redlight
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Won't stay on
sounds like fans are going bad. if you can open the bottom side where the fans are located you can replace it. plug in.
Dec 19, 2008 | Acer Aspire 5100 Notebook
Dell Latitude C610 Laptop won't turn on
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
