Question about Lavazza Espresso Point Capsule Machine
Lavazza machine repair dayton ohio
Does not make coffee
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
SOURCE: lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Posted on Feb 16, 2010
SOURCE: Just need instructions to descale
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Posted on Dec 27, 2010
  • 16 Answers
SOURCE: My Lavazza Blue coffee machine
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Posted on Aug 04, 2011
  • 8 Answers
SOURCE: Lavazza Espresso point not heating up
The electronic control board is defective, it must be repaired or replaced.
To get a dealer address send an email to: f.vitare@lavazza.it. I could help you, but, I live in Canada. Guru
Posted on Nov 20, 2011
Where do i find a repair shop for my lavazza point machine near florida
check with the manufacturer's website . there possibly are none anywhere
Aug 22, 2016 | Lavazza Espresso Point Capsule Machine
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Nov 15, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza coffee machine will not heat up the coffee
Feb 05, 2010 | Lavazza Espresso Point Capsule Machine
Lavazza expresso machine
Is the machine blowing fuses? Your electronic keypad, or circuit card may be damaged.
If you need service you can call 781-393-2929
we are an authorized lavazza distributor and repair center.
Jun 02, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point machine will not turn on.
you will need ten amp, small bus fuses, they are hard to find, I could not find them at radio shack and autopart stores, your machine could have also blown the thermal fuses. if you need service you can call 781-393-2929. we are an authorized lavazza distributor and repair center.
May 14, 2009 | Lavazza Espresso Point Capsule Machine
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
19 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
