Question about Pool & Spa
I have a lawn sprinkler pump, centurion magnetek n56j cx 1.5 hp. It's still working but it started making a loud squeal. Repairable or time to replace? I've had the house for 6 years so the pump is at least that old.
SOURCE: High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Posted on Apr 21, 2009
Coastsider
  • 331 Answers
SOURCE: 1-1/2 hp sprinkler pump hangs up and just hums sometime
The impeller and or bearings are seized. You may have to force the impeller loose (breaking it to get the unit apart). See if you can obtain the bearings and impeller and shaft seal before attempting the overhaul. Be aware that the hardware attaching the motor to the pump housing may need lubrication before attempting to remove.
Posted on Apr 14, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: hot tub pump flo-master hp suddenly wont start.
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 20, 2010
aquaman987
  • 927 Answers
SOURCE: I have a one hp AO Smith electric pump motor for
If you replaced your sprinklers, did you use the same size nozzles as the original heads?
I need more information and I can help you with a well/sprinkler system problem.
Gary
Posted on Jun 18, 2011
uspartscente
  • 717 Answers
SOURCE: I have a STA-Rite
you can take your motor to the local Motor Shop and have them put new bearings in it. That is usually what causes that noise in the motor.
US Parts Center
Posted on Aug 22, 2011
Sprinkler pump makes loud noise when it is running, how to fix?
Typically this sound indicates bearings going out. Usually this means replacing the motor, or may be repairable depending on size and make.
Jan 11, 2013 | Pool & Spa
My centurion pump is leaking
bad seals they are ruining bearings replace whole unit
May 17, 2012 | AO Smith A O Smith Motors Centurion 1/2hp...
Need replacement gears for Nelson sprinkler. Can you help
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 16, 2011 | Nelson LR Rain Train Traveling Sprinkler...
I need the black tips for the sprinkler arms. Where can I order them?
heatman101
Nov 23, 2010 | John Deere Gilmour Traveling Sprinkler -...
Need replace ramp for Nelson Raintrain 1865 traveling sprinklers
heatman101
Aug 20, 2010 | Nelson Sprinkler: Traveling Tractor
My sprinkler has stopped traveling it will travela little then it stops and make a clicking sound and stays stationary how can i get it to start moving.
heatman101
Aug 17, 2010 | John Deere Gilmour Traveling Sprinkler -...
My nelson lawn tractor won't move forward in low or high gear.
heatman101
Aug 13, 2010 | Nelson Sprinkler: Traveling Tractor
High Ringing Noise
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Pool & Spa Logo
105 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
