Question about Garden
How do I replace the hydro pump belt on my husqvarna rz5424 zero turn?
2 Suggested Answers
SOURCE: How do you replace a drive belt on a husqvarna cz4817
i just replaced my belt on a cz 4817. On one side there should be a bar with a spring on it. If you sitting in it it will be on you left side mounted on the deck itself. Push the bar in for about an inch and then up over the lip thats the belt tension spring. you should now be able to remove your old and put the new on. If you need the diagram to show you how to lace the new belt let me know and i will email it to you. good luck
Posted on Jun 16, 2010
My husqvarna zero turn 54 inch will not go forward or backwards. Mowed went to put up and just stopped.
Hydro units usually do not suddenly stop. Check your drive belt on the Hydros. When a Z mower stops suddenly, it is usually the belt or idler pulleys.
Sep 04, 2017 | Husqvarna Garden
The left operating handle does not turn the mower at all. Could it be a belt problem?
Sounds as if the Hyrdrostatic pump may have a stuck valve, or could just need replaced.
May 14, 2016 | Husqvarna Garden
Do I tighten a ground belt from a 2011 Husqvarna rz5424 zero turn lawn mower?
There is not an "adjustment" tension is held by an idler pulley. If the belt is too loose, you must change it.
Aug 09, 2015 | Husqvarna Garden
Diagram to replace drive belt for RZ5424
the library section 629 has many manuals for auto and small engine--or buy one online--may need special tools--if tu much to handle bring it to an independent guy
Mar 02, 2015 | Husqvarna Garden
Zero turn does not go after it gets warm
Sounds like your Hydro units may be going bad. Once they start to fail after they warm up, then the pump inside the units may be bad. It is strange both are giving problems at the same time.
Aug 11, 2014 | Husqvarna Garden
WHEN I MAKE A RIGHT TURN WITH MY HUSQVARNA RZ5424 IT JUST MAKES A GRINDING NOISE AND DOES NOT GO WHAT COULD BE MY PROBLEM?
Where is the grinding sound coming from??? Could be your hydrostatic transmission. When one side goes the other will follow... Time for a new mower... Mine lasted 3 years...
Jul 29, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Husqvarna New Zero Turn Lawn Mower RZ4623 will not go into gear
Not sure the problem, there are no gears on the drive system. This uses Hydro drive wheel units. If the belt is on and in good shape, check the lever linkage.
Jun 22, 2014 | Husqvarna New Zero Turn Lawn Mower RZ4623
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
