Question about Kenmore Dishwashers
I need an owners manual for kenmore portable dishwasher model #587.736610
Older model called a space saver w/power miser
catriver
  • 878 Answers
SOURCE: dishwasher
grazi, your part number for the use and care manual is LIT3368766. You may have to call Whirlpool, thats who made this dishwasher and inquire with them. Im not finding it on any parts suppliers...Catriver.
Posted on Feb 05, 2007
bigg t
  • 640 Answers
SOURCE: Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
Posted on Jan 05, 2008
SOURCE: need user manual
GOT A AEG ELECTROLUX SENSORLOGIC 40660 AS A GIFT
WITH NO MANUAL. I DO NOT NOW HOW TO WORK IT
CAN YOU PLEASE SEND ME A MANUAL TO
R. PRETORIUS
P.O.BOX 128
DENEYSVILLE
1932
THANK YOU
Posted on Jul 23, 2008
SpotBert
  • 231 Answers
SOURCE: need owners guide for 18 inch Kenmore diswasher model 14432/14439
Source => http://www.kenmore.com/shc/s/nb_10154_12604_NB_CustomerCare?adCell=AF
Kenmore Customer Care tells you to go to this site for free owners manuals =>
ManageMyHome.com or http://www.managemyhome.com/mmh/
I found and owners manual and installation instructions there. I wants you to provide an email address.
Posted on Jan 03, 2009
SOURCE: Kenmore ULTRA WASH Portable Dishwasher
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Posted on Sep 12, 2009
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
My lock button wont go off
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
May 20, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore portable dishwasher not working
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Need owners guide for 18 inch Kenmore diswasher model 14432/14439
Jan 03, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
I just bought a used Kenmore portable dishwasher with Model #587 1749581. I'd like to find an owner's manual and parts list for this...in particular the hose adapters to fit onto a kitchen faucet. Can't...
You should be able to go to the Kenmore web sit and down load a manual. If there is a manual you can get it on line. Try google put the model number right in the search.
Dec 09, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
