Question about Garden
What is the gas to oil mixture for a homelite 3816 chainsaw
Gas to oil mixture what is the percentage of mixture?
  • 62 Answers
SOURCE: the percentage of oil and gasoline nedeed
Most saws and other 2 cycle engines use 40:1 ratio gas:oil.
I would not expect yours to be different, unless it is an older saw made before 1980.
Posted on Apr 19, 2009
dontbother10
  • 2220 Answers
SOURCE: What is the gas/oil mixture for a Homelite Z3300
I cannot find a manual and it is not listed at Chain Saw Collectors Corner http://www.acresinternet.com/cscc.nsf. I did find IPLs and judging from them she is no youngster, based on that I am going to say the manual recommends 32:1 (1 gallon of premium fuel to 4 ounces of quality 2-cycle oil).
If properly adjusted up it will start easier, plugs and the exhaust will take much longer to carbon foul on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
dontbother10
  • 2220 Answers
SOURCE: chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Lou
Posted on Apr 03, 2010
  • 4088 Answers
SOURCE: gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
Posted on May 24, 2010
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Whats the oil to gas mixture ratio for a Homelite 42 cc chainsaw?
Use 2.6 ounces of oil per gallon of gas to give you a 50 to 1 ratio of fuel to oil.
Jun 16, 2011 | Homelite Garden
Need to know the gas and oil mixture for a Homelite 2 cycle weed wacker
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
May 22, 2011 | Homelite Garden
I need to know the amount of oil to mix with one gallon of gas for 18 inch homelite chain saw
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Sep 09, 2010 | Homelite Garden
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
GAS OIL MIXTURE
3 oz. 2 cycle oil to 1 gallon fresh fuel and
to keep your fuel fresh add some fuel stabilizer found at walmart for ethanol blended fuel ( it will say marine formula on bottle) and add it to the gas can you fill your trimmer with ,follow directions on bottle for treatment vs. capacity.
May 14, 2010 | Homelite Mighty Lite Lawn Trimmer
Chainsaw gas mixture ratio
Lou
Mar 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
The percentage of oil and gasoline nedeed
Apr 19, 2009 | Homelite ZR10926 16" Chain Saw
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
