Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
My Kenmore 70 series washer model # 110.20722990 will not spin, when I lifted the washer there was a broken (belt?) underneath on the floor. Everything I have investigated looks as if my washer is not belt driven, and it may be the coupler, but what was the belt on the floor, about 22 in circle with 2 notches. Please help.
  • Anonymous Feb 06, 2009
    This is in reference to question by grammi posted Jan.3/09 concerning a no spin problem on a Kenmore washing machine. I too have a Kenmore albeit a different model no. ( 110.4564191) likely because purchased in Canada. I've been able to determine that the problem is a broken motor coupler but was just as baffled by what looked like a belt ( approx. 1/4" thick, black foam-like material ) that was looped around the clutch/brake housing area. It just seemed to be sitting there loosely and I couldn't see any purpose for it. What is it and where is it supposed to go? Note: Person responding to this part of grammi's question said that this was a sound deadening device concerning the brake housing and that it was not really required. This piece is not broken but likely just stretched to where it won't stay put. Any further information on this would be much appreciated. Thanks, Don
  • 198 Answers
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Posted on Jan 05, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore 70 series washer was in spin cycle when the clothes within caused it to become unleveled and it was rocking. I lifted the lid to adjust the clothes to level it and found that lifting the lid
sounds like you need to adjust the feet under machins a little .Lifting lid while runnning is supposed to stop the machine .ans adjusting the wet clothes is mfg suggested fix of unbalance .
Jan 06, 2015 | Kenmore Washing Machines
My kenmore 70 series washer is draining but clothes are still dripping wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Feb 01, 2011 | Kenmore Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly. need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
762 people viewed this question
Sal De
 Brian Main
Brian Main
