Question about Canon PIXMA iP1600 Printer
Cannon printer feed paper
My cannon pixma ip1600 has a paper feeding problem. it can't pass the paper through catridge to print. help please
  • ghanagirl200 Jan 27, 2009
    My paper does not go through at the even path It seems to pull sideways , usually to the right. If it prints at all it is not level accross eyc. and paper is crinckled or ripped
    ghanagirl2004@yahoo.com
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
How do you feed paper into this printer?
Posted on Mar 13, 2009
Paper Feed problems for Cannon MP600
Mechanism Problem replace the mechanism with new one.
Jan 01, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Please tell me how to enable duplex printing in my Cannon MP470. This option is checked on the printing dialog box, but only one side of paper is being printed. Thanks in advance for your help! SMK
The printing dialogue box may allow you to select duplex printing but you may have to physically turn the paper over yourself UNLESS you purchased a DUPLEXER for your printer.
If the paper feeds from the back and the finished product comes out the front, you will have feed the paper back into the back of the printer.
Apr 03, 2011 | Canon PIXMA MP470 All-in-One Printer
Paper unable to feed
Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
All the Best..
Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
Hi! I have canon ip1600 pixma printer. The paper in the printer does not feed properly. It twists to the right. Please suggest what to do.
there is something in the paper path, in an area you cannot see. Look carefully, from the front and back. Often the unit will need to be dismantled.
Oct 18, 2010 | Canon PIXMA iP1600 Printer
How do you fix a paper feed problem in a Cannon iP1600
  1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
  2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
  3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
  4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
  5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
Good Luck!
Aug 23, 2010 | Canon PIXMA iP1600 Printer
I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Jul 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My cannon pixma ip1600 has a paper feeding problem. It can't feed the paper to print. help please.
Jan 03, 2009 | Canon PIXMA iP1600 Printer
'Paper jam msg' when there's nothing stuck in there...???
Sorry can't help. Maybe you have damaged one of the paper jam sensors?
Try the link below which is the manual
http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
Dec 29, 2007 | Canon PIXMA iP1600 Printer
Paper feed
someting fell in the paper feed, first of all try turn the printer around and give it a good shake, maybe it will fall out, if not you need to take the printer apart and remove what ever is there
Dec 13, 2007 | Canon PIXMA iP1600 Printer
Printer feed
A lot of times its something jamming up the feed rollers that suck the paper in. I found a ring, rubber bands, banana stickers and more doing that to other printers
Canon PIXMA iP1600 Printer Logo
299 people viewed this question
old marine
old marine
