Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
ronnie taylor Posted on May 15, 2007
PT-60LC14 screen problem!!!
When I turn the tv on the sound is working fine but the picture looks all messed up like the tracking is off. you can almost make out whats really on tv but there is just a lot of colors and it alternates(colors going up and down and then side to side) for a few minutes before going black. it then usually comes on normal. even then though, it starts going back to having the screen all messed up for a bit. please help...i have no clue whats goin on
marcial nasi
Level 1:
  • Contributor 49 Answers
  • Posted on May 15, 2007
marcial  nasi
Contributor
Level 1:
Answers
49
Questions
0
Helped
12378
Points
86
Try to resolder main board and crt board first then,post me again. hope this help u...
My tv blinks red every five seconds three times pt-60lc14
The temperature sensor has failed its either shorted or open which will cause the 3 blink error
tip
Panasonic PT60LC14 Manual Download
Download Panasonic PT-60LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-60LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-60LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
tip
I hope that helps.
on Apr 27, 2010 • Televison & Video
After conecting my set up, we noticed a yellow square in the middle of the picture.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
6helpful
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
10helpful
4answers
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
