Question about Sherwood R-772 Newcastle 7.1 Home Theater Receiver - Black
No sound coming thought my Sherwood/newcastle r-772 receiver. We did have a loss of power briefly, but the equipment is on a power surge protector.
Receiver is attached to our direct tv. We turn on the power with the Sherwood remote then control everything else through the direct tv controller. Worked great last night but today we have picture with no sound. We checked the mute button and it is not on. We did have a short loss of power early this morning but the system is on a power surge protector.
SOURCE: Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
Posted on Nov 18, 2008
sree-here
  • 61 Answers
SOURCE: Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
Posted on Apr 16, 2009
greenspan
  • 1734 Answers
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    I have a Kenwood audio video stereo receiver model number KRV 7080 where are the fuses located I had a power surge since then it doesn't come on
    take it in for a diagnostic check as power surges bypass fuses and do damage to critical electronic items like the CPU unit
    with modern communication equipment it is essential that quality surge protectors are in the power cord wire
    Feb 28, 2016 | Kenwood Audio Players & Recorders
    Service manual schematics
    It sounds like the device may have been damaged by a power surge. If this is the case, it will not be covered by the manufacturer's warranty. If you had it attached to a surge protector that has a connected equipment warranty (and the device was still damaged), contact the manufacturer of the surge protector and tell them what has happened. They will be able to help you further.
    If the router wasn't connected to a surge protector, your only option is to purchase a new router.
    Jul 17, 2014 | Cisco Linksys X2000 Wireless-n Router With...
    Surge Guard 50amp - no shore power
    Do you have good power that the outlet. I have seen many issues at RV parks of not having sustained power or one leg of the breaker going bad causing loss of power. If you do have good power coming into the surge protector but not out. Then go through the reset procedures for the surge protector. If it will not reset, then the surge protector has failed and will need to be replaced. If power is coming through then check the main breakers in the coach for possible failure. Breakers can trip but still look as if they are properly set. Turn them completely off then back on to reset.
    Apr 09, 2014 | Tiffin Motorhomes 2014 Allegro 32 CA
    Rca lcd tv power surge lighting
    The power supply is a likely place to find what's causing the problem
    Jul 11, 2013 | RCA Televison & Video
    Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
    Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
    If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
    Please see my basic troubleshooting guide here:
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    Parts: www.shopjimmy.com
    Please post back what you find.
    Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    About 8 months old...one channel does not work...I've tried speakers and headset, one channel silent on both... we've had lightening storms, I'm on a surge protector, is it a fuse or a button I need to...
    Did problem happen suddenly, or did the sound fade out slowly over time. Either way, this is not a fuse or button problem. Sometimes the volume knob will fail and you will hear sound from only one channel. May be able to order a new volume knob component.
    Sep 24, 2009 | Sherwood Audio Players & Recorders
    After my house was it by lightning my Onkyo
    If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
    Jul 18, 2009 | Onkyo HTR500 Receiver
    Instalation
    Any good one would be fine!
    Dec 12, 2008 | Sony Televison & Video
    No power
    disconnect everything from the unit and see if it still does it.
    if it does i would check the output transistor (ic).
    Jan 25, 2008 | Sherwood R-945 Receiver
    Sherwood R-772 Newcastle 7.1 Home Theater Receiver - Black Logo
    100 people viewed this question
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
