Emachine latop says press f2 enter setup
Emachines e527-2537 shows the e logo and states press F2 to start. Pressing F2 did not help. I tried to press F2 continuously; it says please wait.. and is stuck there for ever. I removed battery, hard drive and tried everything here http://www.justanswer.com/computer/5909q-when-turn-latop-says-press-f2-enter-setup.html. Still nothing..
3 Suggested Answers
ta_mcguire
  • 125 Answers
SOURCE: medion 2120 stuck on f2 screen
put the cmos battery back in and before you turn it on press and hold down the f2 key should send you to bios where you will have to reset all funcation becase you removed the battery
Posted on Jul 27, 2009
Geekman
  • 32281 Answers
SOURCE: hello, when i start my
The hard disk could be faulty or the Windows operating system is corrupted and in this case Windows need to be reinstalled on the hard disk.
When the hard disk is in the computer and when you go into the BIOS and if the BIOS cannot detect the hard disk then most likely the hard disk is faulty.
Posted on Aug 29, 2011
Testimonial: "thanks alot I got the confirmation I needed"
HOW to tget to bios acer aspire AST180-ED400A
Immediately after pressing the power up button, start repeatedly pressing F2 while the Acer logo is displaying. The Bios setup screen should appear. If you press F2 too soon, the keyboard may not have initialized yet. If you press it too late, Windows will proceed to launch. Press it once, wait a second, press, it again, wait another second, and repeat this while the Acer logo is displaying until you see the bios setup screen.
This is standard approach with most Acers. That said, some laptops may defer to either Ff being the key to press or CTRL+ALT+EXC. Such would be entered as the above mentioned F2. Your Aspire appears to be a desktop and I suspect F2 will suffice.
Feb 19, 2015 | Acer Computers & Internet
Emachines e525 bios password
After hours of searching I finally found a fix:
1. Remove the battery
2. Remove the HDD
3. Removed the RAM to make the solder points, marker 'J1' on the motherboard visible
emachines-e525-bios-password-bueb2fgw15ei4wj3vksvhmc2-2-1.png 4. I then used a paper clip and sticky tape to join these solder points
5. With the solder points joined, insert one stick of RAM and turn the machine on
6. Wait until the laptop is in a post BIOS state (past the screen where you can press F2 for setup and where the logo shows) and remove the paper clip. This has to be removed while the laptop is still on.
7. Turn off computer, press F2 to enter BIOS and you should find there is no password.
Repeat the above steps if you find this doesn't work.
Jun 19, 2012 | Acer Computers & Internet
Emachine when i turn it on says press f2 to start setup but ive tried it but it wont do anything why?
Some keyboards have an f-lock key that you enable quickly as the computer starts to boot. Only then will the F2 button work. If you are too slow to hit the f-lock key the computer will boot past the time window that allows you to enter the setup.
Apr 27, 2012 | Acer Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
How to change the boot priority on emachine?
eMachines - eMonster, eTower, eOne, S-Series, T-Series;
Press Tab or Del while the eMachine logo displays on screen.
Other eMachine computers may use F2 to enter BIOS.
HOPE THIS HELPS
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | E-Machines eMachines Desktop PC
How can I reset my emachine w3653 to factory setting? Unfortunately, I forgot my password. help
Hi! Normally the emachine came with an eRecovery Disk that you can use to restore the PC back to factory settings. To do that follow this steps:
  1. Press F2 to enter BIOS Setup during Power-On Self-Test (POST while the eMachines logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press "F10", then press "Enter" to save the changes and reboot the system.
  7. The computer will boot from the eMachines Recovery Media, follow the prompts to reinstall the operating system.
Sep 14, 2010 | Computers & Internet
Emachine boots into logo screen.pressing F2 no response.
Did it work before?
Have you installed any new hardware or software?
Do you have any USB devices connected?
If so, remove and try again.
Try going into the BIOS to make sure the hard drive is recognised.
I hope this helped. Good Luck and have a nice day.
May 26, 2010 | E-Machines eMachines Desktop PC
None of my usb ports are working. I have went to the device manager and it says that they are operating properly. And also have tried to update the drivers and they all say the drivers are the latest
Hi, Try entering the BIOS and make sure your usbs are turend on turn on legacy usb be carful if you are not sure how to do this,
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Oct 15, 2009 | E-Machines eMachines Desktop PC
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
