The maching washes, and the spin cycle seems to be working, but the clothes are soaking wet. I suspect the pump or a switch.
  • teunisjw Jan 04, 2009
    Maytag Neptune Model MAH4000AWQ. When we washed yesterday, it worked OK, so we have an intermittent problem, ruling out a plugged pump.
  • 163 Answers
Hi!! it looks like you have a bad timer or a plugged drain pump.How old is it?brand and model number?
Posted on Jan 03, 2009
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
My front loading washing mashing is making a grinding sound, it is coming from pump, what is this?
If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 16, 2013 | Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Spin cycle is slow, cloths still extremely wet after spinning
problems with spin cycle could be due to variable reasons.components involved are the lid switch, timer control and the motor.The clothes might be soaked because there could be a drain problem.check whether the drain is clear for partial blockage.also inspect the water pump.
Dec 13, 2008 | GE WWSE5240G
Washing Machines Logo
Top Washing Machines Experts
