Question about Neff Ovens
Need to replace left door hinge on jenn-air oven model w131
Need to replace left hinge
  • 1214 Answers
SOURCE: How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Posted on Jan 16, 2009
lsteward68
  • 331 Answers
SOURCE: My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Posted on Apr 27, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
SOURCE: My jenn-air self-cleaning electronic wall oven
One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
Posted on Oct 14, 2009
iwillfixforu
  • 619 Answers
SOURCE: I have a Jenn Air W131 model wall oven and I
If this is the problem no it isn't hard at all. Should be able to change right thru the oven without pulling out of wall. Make sure power off while doing this tho. But ist make sure broil does work.
Posted on Feb 02, 2010
Testimonial: "Thank you very much. I will give it a try."
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Broken screw on oven door means we cannot change the hinges
Without seeing how or where the screw is located the Idea below may work. I assume, what is left of the screw head is flush with the hinge. See if you can get a drill bit on top of the screw. If so start with a drill bit smaller than the outermost edge of the screw head. Drill slowly until the head of the screw is gone. You can always start small and work your way up to a larger bit. Do not drill into the hinge. Now that the head of the screw is off, you should be able to lift the hinge off. You will now have the shaft of the screw sticking up. I would spray the saft with a penetrating fluid or wd-40. Let it sit in. Then take a pair of locking vice grips and lock on the remanding part of the screw. Now you should be able to turn it to the left like a normal screw.
If you somehow brake the screw off flush with the frame then youll need to use an easy out.
Nov 29, 2013 | Maytag MEW5527B Electric Single Oven
Oven door does not close tightly causing oven lites to go on
Sounds like the oven door is not closing enough for the light to go off. When that happens you have bad hinges. You need a left and right hinge replacement kit. Some hinges are easier than others to change, however, any handy person should be able to complete the job in about an hour with simple hand tools.
Please rate me a "4 thumbs" if this was helpful information. Best of luck!
Dec 15, 2010 | KitchenAid Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Top oven door will not close..appears left hinge not working
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
Hinge snapped on Nardi EK95583AC Range cooker
I have the same problem and am about to replace both hinges and hinge runners (http://shop.ukwhitegoods.co.uk) recommend you should replace both hinges as if one is gone the other will follow soon. The section on the hinge gives a good account on how to replace the hinges safely and how to get to the runners that may need getting into the inside of the oven by removing the sides. I havent gone through this yet so cannot honestly give any more advice other than whats out on the web.
If you follow this link please:
http://tinyurl.com/djntxb
The parts you need are listed there for you. Part numbers 031118009907R and 031199009903R
Adamski
Apr 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Dec 22, 2008 | Ovens
What I need to know to change the hinges on a Turbochef Tornado
Hello. Yes I was going to say, it should be hardest to take the covers off, than anything to replace the hinges. Easier to replace the right one if you take a few items out of the way, and move/disconnect some wiring. Just unplug is the biggest thing, should be ok after that. Guess you figured it out by yourself though. Congratulations :)
Dec 08, 2008 | TurboChef TORNADO Electric Oven
FRIDGIDARIE OVEN DOOR SPRING
Replace left hinge or order for hinge spring. if you want to use the old one, the same problem might happen in short period of time.
Jun 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
82 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
