Question about Dryers
Dryer works no heat not breaker
I have a sears kenmore model 86983810 69838 electric dryer that still works but doesn't heat i've tried resetting the breaker but it still doesn't heat what do i do next?
  • 163 Answers
Hi!! you must always check for voltage first. If you have 120 volts and 220 present then its you thermal fuse that is bad.its a small white oval fuse located near the dryer blower replace that and you should be fine..Good luck..
Posted on Jan 03, 2009
Kenmore dryer 11062062100
If a dryer is not heating - and it is electric, then the first thing to check are the breakers. It runs on a double breaker and half of the breaker may be good (allowing for other functions other than heat). Half breaker will run motor and timer but the element needs both breakers (220v). If that is not the issue, then element may need to be inspected.
Apr 11, 2014 | Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Sep 28, 2010 | Kenmore Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
Sep 28, 2010 | Dryers
I don't have heat to my dryer.
Make sure that Front of the dryer is not blocked, Air flow is needed to dry.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty heating element.You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
I have a 5 year old Sears Kenmore dryer that won't offer heat
This is an electric heated device?
Do you use fabric softener sheets in your machine? If yes, have you tried cleaning the sensor? Look on the back wall for a sensor. Check with Sears for specific instructions.
Sep 21, 2009 | Dryers
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
On heat in dryer
Bad coil/may be your 220V is tripped,so reset your breaker and re try dryer.The dryer will run on half the power.The other half supplies the current to the heating coil.I'll be happy to help you through this.
May 21, 2008 | Kenmore Dryers
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
240 people viewed this question
Top Dryers Experts
