Question about HP P5302M Computer Speakers
No sound and on/off button is on but not the light
My speakers were working wonderfully for a week or so and now after last night watching a movie with great sound, they simply do not work.
  • 1 more comment
  • jennifer toffel
    jennifer toffel Jan 09, 2009
    I found that the problem with my altec lancing speakers was this. After checking sound and audio in computer system, which was correctly set, and that the on/off switch light was on from the speaker button, I checked the wiring and one of the wires was chewed up. The solution? Keep all small kittens away from computer! I spliced wire and wrapped with electrical tape. Works like a charm, magnificently!
  • Anonymous Mar 25, 2009
    same
  • Ulises Tejeda May 11, 2010
    Are you using a laptop with built in speakers or desktop with additional speakers?
  • 9 Answers
Lol. Okay glad to hear that. I'm here if you have anymore problems.
Posted on Jan 09, 2009
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
Oct 13, 2012 | Klipsch SW-112 Speaker
Sanyo DP47460 intermittent sound
Check its speaker. If it is found OK, check and replace the damaged component/s in audio output section circuits.
Jul 22, 2012 | Sanyo DP47460 Diagonal HDTV
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
I have a VSB200. It worked until last night. No sound coming out of it now.
I have the same sound bar and in the middle of watching a movie, it just stopped working. I came to the conclusion that it was the optical hookup on the back of the speaker that had an issue. The problem with the entire situation is that I had only owned the sound bar for around two to three weeks and only watched around four movies on it until this problem. Either a fluke or bad quality. Check your optical connection if that is what you have it hooked up to.
Apr 28, 2011 | Vizio VSB210WS Soundbar
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
HP P5302M Computer Speakers Logo
129 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
