Question about Electrical Supplies
Etq 2250 won't start
Generator won't star
2 Suggested Answers
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
Where is the muffler and exhaust on ETQ prtable generator?
The exhaust will be located on the output side of the cylinder manifold.
Sep 01, 2014 | Eastern Tools & Equipment ETQ Tg72k12 8250...
WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
May 30, 2014 | Honda 3000 Watt Portable Generator
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
I HAVE A ETQ 1200 GENERATOR I NEED ON THE
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
