Question about Husqvarna 28cc Hand Held Blower HVH 125B
How to replace fuel lines on a Husqvarna 125B leaf blower
spekgt
  • 60 Answers
SOURCE: how do you install primer bulb on husqvarna 125b
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
Posted on Aug 29, 2009
boscia
  • 163 Answers
SOURCE: leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
boscia
  • 163 Answers
SOURCE: Husqvarna leaf blower, replace starter cord Model 132 HBV
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
  • 430 Answers
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Posted on Nov 23, 2009
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
Jul 26, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b leaf blower
Have you checked the Flame Arrester in the Muffler. They clog easy and engine can't push out exhaust.
Nov 23, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
When I prime my Husqvarna 125b the gas pours out little vent hole next to the fuel lines going into gas tank? Dont think any gas getting to carborator?What would cause this?
1. Check the pipes to the primer bubble haven't been swapped round, as it sounds like its pressurising the fuel tank.
2. Also sounds like the fuel tank vent could be damaged, this allows pressure to equalise in the fuel tank. Generally it allowa air in but not out the tank, If fuel is exiting the tank then this could have been damaged.
Apr 12, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Repair broken fuel line husqvarna 125b
to replace the fuel line get a piece longer than the old one cut the last 1/2'' down to 1/3 place a stiff wire threw the hole and out the gas cap opening push the line over the hose and slowly pull back till the line pops out then pull the wire out and pull the line threw put the filter back on before pulling the hose all the way threw
Aug 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Nov 22, 2009 | Husqvarna Garden
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 28cc Hand Held Blower HVH 125B Logo
365 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
