Question about Dishwashers
Unit wont start. Breaker is ok, nothing happens when start button is pressed
  • andre551 Jan 03, 2009
    It is model dw2410, installed in a yacht. Is there a reset button anywhere? Must unit we taken out of its wooden housing in the yatcht's galley?
  • andre551 Jan 07, 2009
    We found no current at the breaker. After consulting the boat's electrical schematics, it was discovered that the dishwaswher was connected, via the breaker panel, to a 24V - 240V inverter located in the boat's stern crew quarter. The inverter reset had tripped. Resetting it solved the problem.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, if a reset is installed, it would normally be at the rear, near where the AC power cord comes out of the unit. In some European products, there is a fuse in the AC plug itself as Richie_asg1 has posted.
Since the circuit breaker has been checked, the unit should show some indications that it is receiving power. If none, the START button does nothing and no external RESET switch, then the alternative left is to pullout the unit from its wooden housing. Most units would have a tech sheet at the bottom/kick panel or among the covers/panels. There would also be a wiring diagram that would guide you in tracing voltages at the different points. Foremost to check would be the voltage supplied the controller board.
Good luck and Thank you for using FixYa.
Posted on Jan 03, 2009
    President:
  • 1,952 Answers
Is any thing on or working check to make sure door is latched
  • mohammed marika thambi
    mohammed marika thambi Jan 04, 2009
    the problem might be the start switch itself. if the switch is going
    bad it could have either a carbon buildup on the contacs preventing it
    from starting (unlikely) or the contacs are wearing out and it is more
    hit or miss if it will start. as time goes on the problem will get wose
  • 470 Answers
Specific failure symptoms include: 1) When the dishwasher is turned ON, nothing happens. 2) When the dishwasher is turned ON a “buzzing” sound is heard.
you have 2 choice my dear...
Check Dishwasher Terminal Box
check should be made with the volt/ohmmeter to check if voltage is available to thedishwasher wiring. A voltage check is made by setting the volt/ohmmeter on the 150 A/C scale and placing one probe of the volt/ohmmeter on one wire that supplies voltageto the dishwasher. Place the other probe on the remaining wire. The meter should read 110-125 voltsThis would indicate that electrical power was available from the circuit breaker panel to the dishwasher terminal box.
    Genius:
  • 1,199 Answers
First make sure the door is closed tight...The door switch may be damaged! also check inside of unit and make sure the water level flaot is not stuck or obstructed
  • Dishwashers Master
  • 13,433 Answers
When your diswasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
    Genius:
  • 1,036 Answers
I suspect it is the main door interlock switch. Try opening and closing the door a few times - maybe pushing more than normal to close it.
  • Richard Perkins
    Richard Perkins Jan 03, 2009
    If you don't get any lights - try the fuse in the plug.
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Built in washer drier wont start
What brand and model? Turn off the washer/dryer breaker, wait 15 seconds, then turn on (reset) the breaker.
Jan 19, 2012 | Neff Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
I have a 2 year old ge micrwave. I shut the breaker off to change a furnace filter and now the microwave is not working and just says to "press clock". When I press the clock button, nothing...
If you press clock and nothing happens your keypad has shorted out and needs to be replaced. Try to unplug the unit one more time and try to turn the unit on again. If you have the same problem replace the control panel.
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The dishwasher won't start
nine, when you said the buttons work, do you mean they can be depressed and you feel the clicking? Well if the unit lights up with the indicator light showing power is on then check the float assy it maybe stuck in the up postion and if no power check house breaker/fuse and if ok then the thermal fuse is open somewhere depending on your series of dish washer and generally req some electrical knowledge to follow the electrical ladder diagram ..... this is the only thing I would look for before calling the repairman...
Dec 01, 2009 | Maytag MDB7100AWB Dishwasher
Dryer not working
How do you know the belt is on? Did you take the unit apart? Maybe a connection to the control knob came off. Otherwise:
1) Check the breaker to see if it has been tripped
2) Dryer plugged in
3) dryer door securly closed
4) if your unit is a single knob with various dryer settings, try a different setting (delicate, permanent press, etc)
5) if your unit has a start button, set the knob to the desired setting first, then press start.
Jun 09, 2009 | Whirlpool Dryers
Garbage disposal won't turn on
Three points to ck. !) make sure disposer is plugged in under ther the sink. 2) Make sure the circuit breaker at the breaker panel has not tripped. 3) Make sure disposal is off and make sure it is not jammed, 3) Press reset breaker located on bottom of unit (red button.) Then try wall switch again.
May 20, 2009 | KitchenAid KSU90S0MLL 16" Undermount...
Whirlpool dryer mod#len2000k01 press tha start nothing happens
First thing Is the circuit breaker, then the door switch.
Apr 07, 2009 | Whirlpool Dryers
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
