Question about Sunbeamtech SUNNU550-US-SV Nuuo 550 Watt Power Supply (Silver) Retail (SUNNU550USSV) Power Supply
NO VIDEO SIGNAL
I have an ASUS P5N-E SLI motherboard. Installed are two sticks (1Gig each) of DDR2 RAM, a EVGA GeForce 7950 GT PCIE video card, Intel Quad core processor, etc. When I power on the computer, the mobo light goes on, the PSU powers on, and so does the case fan and the the video card's fan. What fails to go on is the CPU's heatsink fan. Also I get no video signal on my LCD. I tried using a brand new video card to see if the video card is the problem, but I get the same error with the new video card. So the video card is ruled out.
I also tried using a different LCD monitor and I get the same error.
Has you experienced this problem before?
If the problem pointed directly to the heatsink fan, then I should at least get a few seconds of video on my LCD. I get nothing but, "NO VIDEO SIGNAL"
I do see that the fan on the PSU is spinning lightly, not with much enthusiasm.
Thanks
  • dtaveras79
    dtaveras79 Jan 04, 2009
    The microresisters and the capacitors look good. No signs of bulging or browning.
    I will try and test the PSU since I was adviced to do so by a user in a different forum.
    Thank you for you quick response.
    Scholar:
  • 40 Answers
You'll need to check the PSU first, you might want to buy a PSU Tester for 24pin PSUs.
Then you might want to do a in depth examination of your motherbard circuit components by doing the following...
Look for burned/broken microresistors. You might need a magnifying glass and good lighting. Any resistor showing a little blob or browning is burned. Microresistors are those minuscule black,gray,brown or white rectangles lying all over the motherboard's traces. Check first the ones near the power supply connector and near the chips, specially one that says winbond on it, this last ones may get burned from USB overloading, from using non-self powered hubs also called passive hubs.
You may check for blown capacitors, capacitors are those standing cylinders with a plastic cover around them with numbers and letters printed in those covers. On top they are left without a cover and they are aluminum color, they may be flat or have one or more grooves runing across the top. A blown capacitor, looks different from the others because it looks a little bloated on the top, or may have spilled some sort of transparent varnish from its bottom to the motherboard or its top to other components around.
Finally you may suspect of the CPU, athlons get very warm and they can get burned too. Never start your pc without a cpu.
Posted on Jan 03, 2009
No signal. Installed in a Evga x58 3x sli motherboard.
Is the card seated in the slot correctly.
Did you check the bios by tapping the correct key when the computer boots and making sure the computer is set to use the PCI express slot. Sometimes the bios will not allow the PCI express slot to function without manually configuring it to do so.
Feb 28, 2011 | Evga 01G-P3-1430-LR GeForce GT 430...
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
When i try to boot my pc, it continuously beeps
check it one by one first is remove the ram, then then restart it, if nothing use another vga card ..insert the ram and then start again.. else..reset it by removing the battery in few second the start again until you find the couse of that problem..
Sep 13, 2009 | ASUS P5N32-E SLI Motherboard
Usb device over current status detected will shutdown in 15 sec
You can upgrade your motherboard's BIOS with the latest version (downloadable at: http://www.asus.com/product.aspx?P_ID=KyHOsOKWujC2QguJ&content=download). This might help resolve the problem.
If not, then the problem you are having might be because of a bug in Windows 7, since it is not yet the final version.
If possible, you can test whether this is the case or not by backing up your system & installing Windows XP or Vista, and test to see if the problem will persist or not.
Jul 10, 2009 | ASUS P5N-E SLI BULK PACK of 10, Quad,775...
Complience of motherboard and video card on new PC
remove the GFX and try onboard or try chainging ram slots...
Mar 14, 2009 | Evga e-GeForce 9800 GX2 DDR3 PCI-Express...
P5N-SLI
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Oct 08, 2008 | ASUS P5N-E SLI Motherboard
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Computers & Internet Logo
89 people viewed this question
Top Sunbeam Computers & Internet Experts
David Payne
David Payne
Are you a Sunbeam Computer and Internet Expert? Answer questions, earn points and help others
