Question about Bosch Water Heaters AquaStar 125 series Outdoor Gas Water Heater - 125BO
Manual for the bosch aquastar aq-125-blp
I need to clean the intake filter and need a diagram
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Posted on Jun 09, 2009
SOURCE: aq 125 blp Bosch tankless water heater, pilot
Natural Gas: Pilot burner or orfice may need to be cleaned. Pg 11 manual.
http://www.boschhotwater.com/Portals/7/TechManuals/125BL_English.pdf
Most tank and tankless gas water heaters today suggest annual cleaning and maintenance of burner.
Open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BLTechSupport/Troubleshoot/tabid/474/Default.aspx
Posted on Jun 14, 2011
Aquastar 125 blp
Most of these have a safety switch, that would make the pilot shut down. Also check for rust deposits in your fuel line, and pressure.
Aug 23, 2014 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
Sep 24, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
Bosch aq 125 b manual
Open following links for possible manual.
http://www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125B_manual.pdf
http://www.tanklesswaterheatersdirect.com/shop/tanklesswaterheaters/manuals/125BS_manual.pdf
When searching for product manuals on the internet, add .pdf to search parameter.
Search: bosch aq 125 .pdf
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 03, 2011 | Bosch Water Heaters AquaStar 125 series...
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Heater not getting started.batteries are o.k.
Sounds like the 125X unit. This unit has a brass water valve. Be sure to service the water valve every 1-2 years. It is the most common cause of the 125 series heater not working. There is also an inlet filter screen on the water valve that needs to be cleaned or replaced.
Mar 15, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Open Questions:
Bosch Water Heaters AquaStar 125 series Outdoor Gas Water Heater - 125BO Logo
80 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
