Question about Miele Touchtronic G894 SC Built-In Dishwasher
Miele Dishwasher, G984 Funnel for salt dispenser
Need the FUNNEL to be able to pour salt into dispenser. Thank you!
bigg t
  • 640 Answers
SOURCE: miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
Posted on Jan 06, 2008
SOURCE: MY MIELE G856 SC DISHWASHER
press the start/stop and hold for 6 seconds that should clear it.
Posted on Jul 23, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 122 Answers
SOURCE: salt light is on, no manual. What do I do?
Remove the bottom basket from inside the dishwasher - you will see a twist cap on the bottom of the pan - unscrew and add your salt there - it takes about a box to fill. Reinstall cap, and the salt light will extinguish.
Posted on Jan 05, 2009
SOURCE: Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Posted on Jan 29, 2010
I poured a lot of salt in my dishwasher. What can i do?
Do you mean dishwasher salt?
Did you pour in free handed instead of using a funnel and it ran over? Just scoop out the extra.
Here is a link for dishwasher care and salt use.
Dishwasher Care tips for getting cleaner dishes from dishwashers
Nov 27, 2015 | Dishwashers
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
What is the funnel thing that came with my dishwasher danby ddw1899WP?
The "funnel thing" is exactly what it looks like- a funnel. It's for adding the salt to the water softener located on the "floor" of the dishwasher:)
Nov 23, 2010 | Danby DDW1899WP Portable Dishwasher
My dishwasher is flashing for salt it is a Miele and i want to know what kind of salt to put in and how much - i have the plastic bowl thing to put it in the dishwasher
Use the salt supplied by your service provider. Or try in a super market.Ask for dish washer salt.
If a plastic funnel is supplied use it to fill the salt compartment. The quantity as it holds.
Do not fill kitchen salt used for food!
Sep 30, 2010 | Dishwashers
Film on dishes and inside stainless steel panel
You live in a hard water area. Even though dishwasher tablets have salt included you may have to fill the machine with extra salt. (its the large srew top cap in the bottom of your machine, open it and fill it with dishwaher salt your machine came with a large funnel to help you do this) you will have to remove the bottom drawer to do this. next make sure you have rinse aid installed in the door of your machine, next to where you put the tablets in (don't buy cheap rinse aid it's not worth it) when its full of rinse aid the indicator will turn dark, will need both salt and rince aid about every 30 cycles.
Nov 05, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Jul 08, 2009 | LG Refrigerators
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Ice and Water Dispenser Funnel
This diagram may help some.. should be a molding thats goes around outside of dispenser.. should be able to pop off and get at screws u need to get at...to remove and get at what u need too
http://www.partselect.com/Schematics/GE/00116598i01.gif
Nov 01, 2007 | Refrigerators
Miele Touchtronic G894 SC Built-In Dishwasher Logo
91 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
