I need to replace a DynaVent wall gas furnace. I'm not sure if the original I had was a 25BTU or 40 BTU model, but it fit into a Rough Opening approx. 20.5 X 15 inches. Where can I order a replacement furnace?
  • 15 Answers
SOURCE: Venting a Dayton 4E454 24,000 BTU gas furnace
If you intend to use this in a residential garage, you will have to use standard galvanized round pipe coming off the unit, 24 gauge will suffice, use a minimum of 6”-8” from the unit. From there you will have to make the transition to the B-Vent. Always double check with you local codes in your area.
Hope this helps.
Posted on Dec 02, 2008
  • 35 Answers
SOURCE: Looking to find an owner's manual for an old furnace
I remeber we took out a Coleman kero heater out of my grandmothers mobile home. Just had it repaired but she wanted a new unit. Would have to go and check to see how many BTU's it is and also to see if the book is there as well.
Posted on Jan 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have 210k btu Magic Chef gas fired furnace and I need a model #
Replace the start capacitor. Take an amp draw on the motor when it starts. Compare that with the rating plate for FLA.
Posted on Nov 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a newly installed 35k btu natural gas wall
The disc is doing its job, saving your life! If the heat exchanger gets too hot this disc is the safety. Find out how hot the heat exchanger is getting and what the disc is rated for. Check that there is air flowing over the heat exchanger keeping it from over heating. If your vent was installed incorrectly it could be keeping too much heat inside the furnace not allowing it to escape to the outside.
Posted on Dec 29, 2009
  • 415 Answers
SOURCE: need replacement PVC vent pipe elbow with outlet drain
That's going to be a specialty item that you will have to go through the manufacturer for. Also, You will most likely have to add a coupling or two in the pipe. Once you cut the old elbow out, the pipe on each end will be shorter than what you had before. That size pipe is usually tight in place and not easy to shift around. When you purchase the fittings, you should also purchase the primer and the glue needed to do this job per code. If not done per code, it could lead to personal injury and or death as this is the pipe that contains Carbon Monoxide when the furnace is running.
This type of job appears simple but, due to clearance issues, can be troublesome for even the most seasoned mechanics/installers. I would recommend this job be performed by a licensed/qualified contractor.
I would have liked to offered a precise place to obtain the fitting and to say it's an easy job; however, it's a bit more complicated than it appears.
Here's a link to the Goodman Manufacturing with a dealer locator.
http://www.goodmanmfg.com/
Though it may not be the answer you were hoping for, I do hope you found this information helpful to you. Good Luck in your endeavor! :-)
Posted on Mar 11, 2010
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Dec 29, 2009 | Cozy (W352E) Heater
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Nov 09, 2009 | Empire Hight Efficient Direct Vent Wall...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Heating & Cooling Logo
1,065 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
