Question about Filter Queen Majestic Canister Vacuum
Water inside Peugeot 206 rear light clusters
As these are supposed to be sealed - how do I remove the water or prevent it happening again ?
  • jillbri Feb 07, 2009
    I have just had a brand new sealed unit fitted and still there is water inside the unit !!!
  • merlemad Mar 07, 2009
    exactly the same problem it keeps causing corrosion and light failure, any ideas on how to rectify it would be appreciated.
    Problem Solver:
  • 16 Answers
Don`t worry this will hold no problems happen in alot of cars and will eventually find it`s own way out or evaporate in the heat, then it will become misty then go away.
Posted on Aug 20, 2009
My Bissell carpet clean will not extract water
Possible the water pump has gone out. I changed mine out it was not too hard.Also make sure the pump lines are all still attached and not clogged.This will take a little dis-assembly.
May 17, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
I pumped my steam mop to get started as I always do. I heard a loud pop and now it won't produce steam and leaks water on the floor.
The mop broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jun 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water coming out
On my LGM, the motor that drives the soap pump had siezed. I disassembled down to the pump and separated the motor from the pump. With pliers, forced the motor shaft to turn and sprayed lubricant (lithium grease) onto motor's front and rear bearings.
Heater box is a little tricky to remove. Remove 4 screws to remove top plate. Lift heater out and remove insulator. Remove two screws from inside box to remove heater box bottom.
Nov 15, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Bissel Quicksteamer leaking
Hi there SmartAlec from NelsonVacuums.com.au here. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Constsntly applys water even when shut off/ not running took apart handle I believe trigger is broken
Hi there SmartAlec from NelsonVacuums.com.au here. The trigger definately could be broken but before you take it to a repairer i would really thouroughly clean any little foam filters and rubber seals you can find. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
5914-900 not sucking up the solution
There's a leak somewhere! This also happened to me. Take both tanks off and clean them thoroughly. The rubber seal on the bottom of the water receptacle tank has to be seated firmly and the tank locked down with the little arms (one on each side). Pet hair clogs this model and has to be removed after each use. Look for debris, etc that may be preventing the tank from sealing properly.
Jul 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Nov 06, 2007 | Bissell ProHeat Turbo Deep Cleaner Upright...
Have a hoover steam cleaner F5837-900 model
First off, check the dirty water tank, check the round filter on the bottom of the lid to make sure there is a gap and pushed all of the way up, then make sure that the lid is locked onto the tank. Check the bottom of the tank, push in the plunge to make sure water comes out freely. There is a round seal where the water tank sits, make sure it is ok. There is a diapham that the tank sits on could be bad, or the tube running down the inside of the handle is crimped. Could have a bad pump. but they don't go bad very often.
Nov 04, 2007 | Hoover F5906-900 Upright Steam Vacuum
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Filter Queen Majestic Canister Vacuum Logo
1,100 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
