Question about Hammering
What is the oil capacity of model 01919 troy built 5550 watt generator ?
There is no dip stick on this product ....... trying to find the spec for oil capacity ....... it has a10 hp ohv briggs &straton engine .......
SOURCE: generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Posted on Sep 21, 2008
  • 32 Answers
SOURCE: I have a Briggs & Stratton 6.0ohv on a lawn
someone put the wrong cap on your engine. 2 strokes don't have ohv
Posted on Jul 20, 2009
mowerman1857
  • 389 Answers
SOURCE: what is the oil capacity of the briggs ans straton
Approximately 40 ounces. Put in a full quart first, then add about 1/4 of the second quart and start checking the dipstick until you are at the full mark. Each time you add more, let it run down into the engine for a minute or so before checking or you will get a false reading. If your engine has an oil filter and you changed it, figure about 2 extra ounces for the filter
Posted on Oct 10, 2009
SOURCE: No power output from Briggs & Stratton ProMax 7500E generator
check the AVR.
Posted on Jun 14, 2010
  • 44 Answers
SOURCE: My John Deere 318 briggs & straton v-twin 18HP is flooding out
need carb kit with nedle and seat
Posted on Sep 09, 2010
What weight oil does a 5550 watt take?
According to Generac for there Portable generators they recommend, Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter. Here is a link to get a manual if you need one. You will need your model number.
http://www.generac.com/service-support/product-support-lookup
Jan 30, 2016 | Generac Electrical Supplies
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
Briggs 5550 model 030253 generator spits oil
I'll take guess here, broken ring. You did mention where it was spitting oil from? GB...stewbison
Sep 05, 2011 | Briggs & Stratton Power Products 5,550...
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
What type oil do I nee4d for a 10hp ohv Mdl 01919 used on a troy built generator
For most Briggs engines / from the Briggs web site :
Oil Recommendation
  • SAE 30 40° F and higher (5° C and higher) is good for all purpose use above 40° F, use below 40° F will cause hard starting.
  • 10W-30 0 to 100° F (-18 to 38° C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80° F(27° C) or higher.
  • Synthetic 5W-30 -20 to 120° F (-30 to 40° C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
  • 5W-30 40° F and below (5° C and below) is recommended for winter use, and works best in cold conditions.
Type of oil to use
  • Use a high quality detergent oil classified "For Service SF, SG, SH, SJ" or higher.
  • Do not use special additives.
  • Choose a viscosity according to the table above.
2978e398c0ac447584fe192e2a57cfbc.ashx
50a40449f9a74cc9a5d6c460f40284d0.ashx
Back to Search Results
Jul 04, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Mar 29, 2009 | Electrical Supplies
Hammering Logo
345 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
