Question about Electrical Supplies
My Titan 8500 generator is leaking fuel at the caboretor
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
blown725
  • 15 Answers
SOURCE: titan 7000 generator...the generator is not
you know , i have helped several people on thire cars , i want a fix and you want money...not faiir at all....i thought this sight was a helpful sight...i see diferently now....thanks
Posted on Sep 03, 2009
rwvanlue
  • 486 Answers
SOURCE: My Honda EM650 generator quits running after 15 to
'Vent is leaking while running': can be caused by varnish on the inlet needle/seat and debris in the float bowl.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Colman Powermate Generator will not stay running
This overflow can be caused by:
1. The float sticking
2. Gas inside of the float air chambers
3. The needle and seat have debris in them or a r damaged.
It is not a difficult fix but it does mandate removal of the carburetor float bowl.
You could probably do this yourself. It is much easier if you place the generator on a high work area so you can see the float and needle once you have the float bowl removed. Just make sure you do not drop the float assy so far that the needle comes out of the seat unless you have to remove the hinge pin SCREW for the float to clear the debris near the needles' pointed rubber head.
Thanks for using FixYa
Kelly
Posted on Mar 22, 2010
jeff_drakesr
  • 155 Answers
SOURCE: titan tg9000es generator won't start.
When you are pull starting or cranking over the engine with choke on due you smell any fuel (Flooding of the Engine) if not then try removing the sparkplug use a small amount of gas and pour into cylinder. Reinstall the spark plug and try starting if it starts briefly then dies it is most likely fuel. Check filter and fuel lines (rubber fuel lines grow weak and can collapse not allowing the fuel to pass. If It doesn't start check the compression by placing your thumb over the spark plug hole if there is little push back the you have a compression problem should then verify with a compression tester. Overhauling the engine then might be necessary. I hope this was helpful, please give a rating if the answer was of help. Good luck and have a great weekend.
Posted on Apr 04, 2010
Testimonial: "Good tips on how to eliminate several possible problems."
Manual for a Titan 8500 generator. Urgent.
Check with manufacturer on their website.
Oct 06, 2016 | Electrical Supplies
Titan generator 8500
Try exciting the field with drill. Plug it in to generator pull the trigger and spin the drill backwards by hand.
May 24, 2013 | Electrical Supplies
Titan 7000 generator...the generator is not
Sep 02, 2009 | Electrical Supplies
Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
141 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
