Bosch hsb745055E/01 oven works in normal (non-fan) mode, but does not heat up in fan mode (fan with circle round it), even though the fan works
SOURCE: bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
SOURCE: Bosch oven won't pre-heat/heat with door closed
hi ,
according to me ,there is some issue with the cables that are connected the heat functionality of oven , because the same happned with my lg microwave , then the tech checked it , it was a cable fault , one of the cable was loose when the door was fully closed microwave was not working but when we leave some space while closing it it was working , so it is recomended if your oven is in warranty the call the company technicans to fix it , plase dont try if dont have expertis on it take help of tech who knows about microwave
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: Bosch HBN745 Single Convetion Oven - Fan won't stop & still maintains heat
Sounds like it is the thermostat that is faulty.
Go to your browser bar and type in youtube.com
Then in the search box type in fitting thermostat to oven
Click on appropiate video and follow instructions, this should help with your prob.
Plz rate my solution.
Thanks.
youtube.com
