Question about Jacuzzi R100-959 Cetra 536 RH R100 Whirlpool Bath, White
Defective power switch on jacuzzi espree 6060 tub
4 Suggested Answers
uspartscente
  • 717 Answers
SOURCE: I have a Jacuzzi tub and the vacuum switch will
if when you push the air button it will not turn off the pump, it may be the button that is bad on the top of the tub or the air switch located in the motor.
take the pump out and plug it into an outlet. get a straw and blow into the air switch with the pump plugged in still. if it comes on then the button on the top of the tub is bad. if it doesn't come on then the air switch is bad.
Posted on Feb 17, 2011
  • 81 Answers
SOURCE: Our Jacuzzi Espree 6060 corner whirlpool stopped
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
Posted on Jun 03, 2010
uspartscente
  • 717 Answers
SOURCE: I have the espree 536
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Posted on Jan 17, 2011
I have a Espree 536 and need to replace the magic air switch. The tub is enclosed with a tile mosaic front which I do not want to have to remove if at all possible to replace the switch.
it is possible that the switch is held in place by a nut from underneath
see if you put your hand up under the panel to see if there is a nut there
Oct 11, 2015 | Jacuzzi Home
How to fix jacuzzi tub will not shut off bubbler
if the air blower will not shut off then it will either be the air switch in the blower or the control module that operates the blower will be bad.
Sep 11, 2014 | Jacuzzi Home
I have a jacuzzi espree 536 model U640. The jets would not shut if with the switch. I unplugged the unit and now it will not turn on
When a jetted tub will not turn off it is usually because the air switch in the motor has quit functioning.
A new air switch for your pump costs around $20
US Parts Center
Oct 27, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Hi, I am wanting to download and print out the installation manual for: Jacuzzi 60'L x 32"W x 22"H Espree 1-Person Hourglass Whirlpool Tub. I want to read this before I purchase this tub. ...
Hi Pat,
The installation manual should be available on this webpage but there seems to be a broken link when you try to download:
http://www.jacuzzi.com/baths/options/models/espree-6032#
You can e-mail Jacuzzi from the webpage and they should send the pdf install document out to you.
Hope this helps!
May 10, 2011 | Plumbing
Our Jacuzzi Espree 6060 corner whirlpool stopped working after about 15 months of light use. I called the company and they had me order an air switch. Our motor does nothing. No clicking. GFI is working. I...
May 30, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Espree 7242 pump/motor will not shutoff. Manual says to reconnect tube to Magic Touch switch or to air switch pumpmotor. Do I have to pull the tub out? It sits in a tiled skirt.
There should be a removable panel either around the skirt or in the ceiling below the tub to access electronics and plumbing to repair.
Jan 09, 2010 | Tools & Hardware - Others
Jacuzzi R100-959 Cetra 536 RH R100 Whirlpool Bath, White Logo
233 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
