Question about Whirlpool Gold 30 in. Electric Convection Wall Oven with Built-In
I need to replace a thermal fuse on a built in Whirlpool Gold Series oven
SOURCE: WHIRLPOOL OVEN
nice, it'd help me a lot thank you
Posted on Jan 19, 2008
revamos
  • 16 Answers
SOURCE: Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
Posted on Apr 19, 2008
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 1416 Answers
SOURCE: Where is the thermal fuse
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Posted on Oct 10, 2010
    If the thermal fuse is out on oven will the microwave still heat
    If the Thermal Fuse is out, the oven will not get hot. you will need to purchase the fuse and replace it for it to work again. You will need to pull the oven out becuase the fuse is on the backside of the oven.
    Jun 02, 2014 | Whirlpool GBD307PDS Electric Double Oven
    Whirlpool gold single oven - YGBS277PDB7 - The power failure signal has started to show up during cooking and everything shuts down even though there is power. what part would need replacing?
    Turn the breaker off before you start. To isolate this your going to need to remove the oven from the wall. Once done, you'll need to remove the top of the oven so you can see down inside of it. Starting at where the wires come into the machine, you're going to trace the wiring to each of the parts in series. These parts include the thermal fuse, lock mechanism, wiring, etc.
    May 22, 2012 | Whirlpool GBS277PRS Stainless Steel...
    Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
    The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
    GENE
    Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
    I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
    The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
    Aug 27, 2011 | Whirlpool Ovens
    After self cleaning the display is blank and door is locked
    Which thermal fuse did you replace?
    There are 3.
    This manual will help you diagnose the oven.
    Thermal fuses are explained on page 3-2.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
    Jul 11, 2010 | Whirlpool RBD305PDS Electric Double Oven
    Built-in Whirlpool model GBS307PRS01 oven won't get hot
    First check the thermal fuse to see if it's open circuit and if so replace with http://www.appliancepartscompany.com/product/9223815
    This is normally the problem (I have already replaced it twice on my oven).
    If this doesn't solve your problem, let me know as there are some other option to try.
    Jul 08, 2010 | Whirlpool GBS307PRS Stainless Steel...
    Display reads code F03 on Whirlpool oven. Can I
    Hi
    Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
    No power and door locked after starting self cleaning cycle
    Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
    Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
    Whirlpool electric oven problem
    thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
    Sep 22, 2008 | Ovens
    Whirlpool rbd275pdb double wall oven died during self clean
    Mar 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Whirlpool Gold 30 in. Electric Convection Wall Oven with Built-In Logo
    49 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
