Question about Garden
Need driving core for spin saw kit 54-8205-8
The driving core of the flexible shaft assembley broke an i called the phone number that is in the manual to order a replacement part an they told me that they dont have that replacement part but if it was still under warranty to take it back to the store an get it replaced. so now i have this tool that i paid good money for that is now just a piece of junk . you would think that if they are going to sell there merchandise to us that they should be able fix the problem an if they cant then they should rembuirest us our money an be loyal to there customers as many customers are loyal to them even having had this problem i still shop at there store , hope someone can help me
patrikspongh
  • 47 Answers
SOURCE: fuji fp-988d owners manual
All I could come up with is a number for parts.. Maybe you could call it and find the right number?  1-866-925-7278. Give a try!
Posted on Oct 12, 2007
  • 211 Answers
SOURCE: craftsman 42cc chain saw
Hi
First change the plug with a new one with the same heat range.Clean the cilinder wings and the fan housing holes.Check the air and gas filters(clean them).Change the gas from gas tank.Dsassembly,check and clean the carb with compressed air.
Start the engine.
best regards savumihai71
Posted on Feb 12, 2009
dontbother10
  • 2220 Answers
SOURCE: Need Service manual for Mcculloch 3516 chainsaw
PDF = Adobe; a free easily downloaded program. Get the PDF manual. Get an updated version of Adobe. Open the PDF hit print and you have a manual.
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: I would like to get a parts manual for a remington
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
Phone Number is atop the linked page. HTH
Lou
Posted on Dec 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
Mastercraft Maximum spin saw kit 54-8205-8 Where can I obtain a flexible shaft part # 2221-MA0006-01
Type "Sears Parts Direct" into your computer search engine, along with the make and model number, and see if they recognize your machine.
If so, they might have a part for it.
I would also try "e-bay" or Amazon, but you will need the part number of what you want first, I would say.
God bless your efforts.
May 03, 2016 | Saws
Trimmer head won't rotate
Usually this is a clutch problem, the clutch is under the drum and when it engages turns the drum which turns the drive shaft which turns the trimmer head. If the drum is not turning than it is the clutch, if the clutch is turning the drive shaft could be broke, if the drive shaft is not broke than the problem would be in the gears of the trimmer head.
Apr 11, 2014 | Stihl FS 85 Weed Eater
1986 Alfa Romeo Spider Drive Shaft Support
Did you try to get some assistance form the dealer? Try to google for the info?
Sep 11, 2017 | Cars & Trucks
Flexible shaft adapter for a Mastercraft Maximum Spin Saw Kit 54-8205-8. Canadian Tire doesn't stock parts does anyone know where I can get parts?
I think I may have the same kit (#54-8204-0-).
I called Mastercraft at 1-800-689-9928 and they told me that these were under a 3 year exchange/replacement warranty, and after that we are out of luck (the stores do not stock parts, and unless they have some returned kits around, there may not be parts available).
I asked about the current zip saw (Click this link) and am hoping that parts from that will work. The girl at Mastercraft gave me the number for Powertools plus / JinDing (who make this tool), and I am going to call them and see if I can order the collet that drives the flexible cable (1/4" collet to the small square of the cable).
Their number is 1-877-683-2082.
I am hoping that these are fairly standard, and that the collet will fit.
May 08, 2012 | Garden
I have a Poulan 810EPT electric motor that has worked great but now my attachments won't slip and lock into the end of the shaft. Can't see any obstruction except maybe the flexible cable on the...
This sounds like the flexible drive shaft inside of the main shaft has a stripped ferrule. In order for you to fix this, you will have to take the main shaft off of the motor housing and pull the flexible shaft out of the inside. The replacement part number is 530056570 and should be about $12 to replace. Call the number on the unit to order replacement parts or go to your local sears.
Aug 27, 2011 | Poulan Garden
Flexible Shaft Adaptor # 2221-MA00009-00 Carbon Brush # 03AT-000046-00 Brush Spring # 02AH-000088-00 For a Mastercraft Maximum Spin Saw Kit Model # 54-8205-8 Cdn Tire...
By robert_lessa on May 09, 2011
Model # 54-8205-8
Cdn Tire doesn't support their own "house" brand with spare parts.
Does anyone know who was contracted by Cdn Tire to make this unit? That could give me an alternate source for spares. Any help would be much appreciated.
Thanks, Bob
------------------------------------------------------------------ Canadian Tire stopped supporting this product in 2008 and have no parts in inventory ( I am not convinced they ever had a stock of parts) The Spin Saw was manufactured in China by Choon Nang Electric. Your best bet is going to a small engine repair shop and ask if they have universal parts which could fit. Best of luck Claude
May 09, 2011 | Garden
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
My handle broke off on my hitachi table saw c10ra3 need to replace it . It is for the rip fence to lock in place. most places i look you had to buy the hole assembley i just need a new handle
go to garage sales and try your luck. ive had the same problem with differant brands and had to replace the whole thing. check manufacturers web site or your owners manual and see if its a replacable part with a part#
Apr 22, 2009 | Hitachi C10RA3 10" Table Saw With Stand:...
Wheel in Hoover SpinSrub turbine broke
Sorry, you will not find that one part available for sale. You will need the assembly from the manufacturer, or may check online sales/auctions.
Nov 20, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
